03-11-2010, 07:55 PM | #1 |
Newbie Join Date: Aug 2009 Location: Lincoln
| can i get help
well i have had my creeper for 4 weeks now and i broke the c hub and i bent the pin i am not worried about the c hub i can buy one at the lhs but the pin is not sold as one unit so what can use for a pin
03-11-2010, 08:02 PM | #2 |
Rock Stacker Join Date: Nov 2009 Location: Seattle
You could try to straighten the pin, or take it the the hobby shop and see if you can match it up to one from another kit, such as traxxas or something popular. If you can match the diameter, you can always cut it down if it's to long. Might try the local hardware store and see if they have any small pins like that that are hardened steel.
03-11-2010, 08:04 PM | #3 |
thanks i try the hardware first then the lhs
03-11-2010, 09:31 PM | #4 |
Newbie Join Date: Jan 2010 Location: Walnut Ca
I had the same problem u had too when I went out for the first time checked the lhs and didn't have any so I found one of these clips lying around and I just cut it to fit and haven't had a problem with it bending when it's come out well hope this works for you |
03-12-2010, 07:25 AM | #5 |
Rock Stacker Join Date: Aug 2009 Location: Denmark
Just buy some piano wire and cut to lenght, that will work fine.
03-12-2010, 06:27 PM | #6 |
Rock Crawler Join Date: Mar 2008 Location: hillbilly illinois
03-12-2010, 08:25 PM | #7 |
Rock Crawler Join Date: Feb 2010 Location: eugene
another idea is what i did. went to the lhs and they didnt have any pins in stock so they gave my a drill bit, that i cut to size (smooth part) and works great.
