02-08-2011, 08:21 PM | #61 |
Quarry Creeper Join Date: Dec 2009 Location: Brentwood
when you had the stock chassis on, did you mod the shocks at all? or just stock setup?
02-08-2011, 08:26 PM | #62 | |
I wanna be Dave Join Date: Jan 2006 Location: ...the burning end of the rope.
BMT's Sportsman Creeper BMT's Sportsman Creeper this is much better than stock and what I was talking about. | |
02-08-2011, 08:42 PM | #63 | |
and do i have to use different upper links? | |
02-08-2011, 09:10 PM | #64 |
Quarry Creeper Join Date: Dec 2006 Location: Tasmania
No, I have not had the caps off the shocks since they went on the first time. I have not tried it, other than around the house, in this format (with an over size battery hanging off the front links) but the stock internal springs might just cut it in a full droop set up. No noticeable twist or lift while crawling couches, door frames, cats etc. A link change is kind of mandatory once you start screwing with geometry on a crawler. You just can't make a change to one side of a triangle without adjusting the other two, know what I mean?. |
03-06-2011, 05:22 AM | #65 |
More refinement... Hopefully will be up and running at this month's cANZ comp |
