Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Venom Creeper
Thread: jebster's creeper
Old 06-12-2012, 10:18 AM   #241
Default Re: jebster's creeper
Thanks Jeff...Ive had so much going on that I just wasnt seeing the simplicity of the weight system...youve done the hard part..Kudos for that...Ill be ordering materials this week or early next week...I am going to adjust the design for set screw mounting of the main ring to the knuckles and look at a couple of options for mounting the sub-rings...
Either way...the new Paradox "J" Weights..."J" for jebster...will be along soon...thanks again Jeff for breaking the ground...
rmdesignworks is offline   Reply With Quote
Old 06-12-2012, 03:05 PM   #242
Originally Posted by jebster View Post
i listed the weight a few posts back. here it is:
Knuckle mount - 1 5/8 oz
Full ring - 1 3/4 oz
Half ring - 7/8 oz
Per side that gets me to 4 1/4 oz and change for the hardware
sounds good to me, good work man.
everyone, just wanted to put an acknowledgement out to thomas of rmdesignworks. he's looked at my idea and is going to be exploring the production of this knuckle weight system. given his ability to create and refine ideas and bring them to market i'm sure it will be another great addition to his product line. if my simple concept helps benefits others i've done my part.
thomas, i'm looking forward to seeing where this goes!
well got the eye of thomas so u deffintly got a good idea going. great job bro
looking forward to it. it will deffintly be a cheaper way off putting nuckle weights on than having to switch to the 8* VP knuckles and weight system
venomcrawlerdud is offline   Reply With Quote
Old 06-13-2012, 08:09 AM   #243
Thank you jebster! This will be awesome .. I can switch to some diff wheels now, maybe some slw v2 in black! Yeah..... "j" weights are the deal.. thanks again for ur time an effort!
winnerone23 is offline   Reply With Quote
Old 06-24-2012, 12:38 PM   #244
jebster's Avatar
Got some upgrades. First up was creeperbob straight titanium rear axles. Awesome! No more slop or wiggle. Next up was VP wheels. I added some new wheels to my xr10 which freed these bad boys up for the creeper. I will be switching the sedonas over to rovers but you get the idea.
jebster is offline   Reply With Quote
Old 06-24-2012, 01:25 PM   #245
Yashua
CREEPERBOB's Avatar
Looks good Jeff, and glad you like the Ti axle shafts , that will take 20 + gms. off the rear axle too.
CREEPERBOB is offline   Reply With Quote
Old 06-24-2012, 02:05 PM   #246
rig looks really good Jeff i think your they only one that i know of that's still running a 4vp chassis and having good success with it
Old 06-24-2012, 02:23 PM   #247
jebster's Avatar
great product. fit like a glove. and the reduced weight in the rear will help to shift the cg a little more forward, something i wanted.
yeah, i still like the 4vp. has enough adjustability for my needs. as to whether i'm having good success or not is a whole separate question! i have a comp next weekend which will be the first time i'll get to try out the new rear shafts, knuckle weights and vp wheels in action. hope all goes well.
Old 06-24-2012, 07:17 PM   #248
do good bro
Old 06-25-2012, 05:35 AM   #249
That's a sick looking rig! The wheels look great on there with the front knuckle weights! Sure can't wait till there in production...
Old 06-25-2012, 07:06 AM   #250
Awsome looking rig. I have the titanium shafts too. They are so far indestructible. Now he just needs to make the fronts!! Get to it Bob!!
mgputer is offline   Reply With Quote
Old 06-25-2012, 08:00 PM   #251
X2 on the fronts.... Just changed one of mine out...
Old 12-21-2012, 11:33 AM   #252
jebster's Avatar
It's been awhile. Decided to swap the slw wheels for some custom made lightweight rims. The only issue was the offset wasn't working out so I had to make some spacers. Just used a hole saw bit and a slab of delrin. It worked out good.
Weather sucks so it may be awhile before I get it out for some testing. In the mean time here are a couple pics.
Old 12-21-2012, 08:19 PM   #253
Verycool rig, them wheels are sick as well! What's th rtr weight?
Old 12-22-2012, 09:02 AM   #254
jebster's Avatar
ready to run mine is 5lb, 4oz. I haven't done much to trim weight but it does work pretty good for me.
Old 12-22-2012, 09:47 AM   #255
That's pretty light tho! Like 12oz lighter then mine!
Chassis prolly a part of that, an wheel weight.. I don't have any complaints on how well a creeper can crawl! Heavy or not, its a great rig setup
Old 04-10-2013, 06:46 PM   #256
jebster's Avatar
The local club is running the bodied 2.2s class so I needed to change things up. Decided to completely remove the existing chassis out and went back to the basics, ie the original creeper chassis plates. I kept the links and axles all the same but used xr10 shock mounts to lower the upper shock mounting points. Lowered the entire rig down for a lower cg. I took it for a test run and I really like the way it rides.
I have an xr10 hardline body on the way to give it a nice sleek look.
Can't wait to get it out for a comp. Now for a few pics.
Old 04-10-2013, 08:58 PM   #257
Pretty cool build! I wanna see some video!!
Exocaged is offline   Reply With Quote
Old 04-11-2013, 05:24 PM   #258
jebster's Avatar
Thanks. If I get time this weekend ill try to get it on my practice course and take some videos.
Old 09-17-2013, 07:16 PM   #259
jebster's Avatar
Been awhile. So, earned a ticket to nationals in Prescott AZ so me and the creeper went on a trip. First major comp I've ever been to. Did OK in my book (54 of 75 in 2.2s) and I was really happy with the rig. I do believe I was running the only creeper in the field.
The nationals highlighted to issues with my creeper: 1) I need more steering and 2) the skid is a major hang point. I decided to work on 2 first. I figured that I could lay the tranny on the side. It would keep he driveshafts low and drop the motor down for better cog. Out came a slab of derlin and I started milling. Got it finished up and I'm pretty happy with it. Need to get it out on he rocks to see how it performs but I'm confident it will be an improvement.
Here is a bunch of pics.
Old 09-18-2013, 07:19 AM   #260
dude thats awesome!!! I woulda never thought of that!
