07-23-2011, 01:13 PM | #101 |
Yashua Join Date: Sep 2010 Location: Learn the parable of the fig tree
Any pics of the progress on the links? Man those c hubs will surely have some strange steering if backwards.
07-23-2011, 01:27 PM | #102 |
I wanna be Dave Join Date: Jan 2006 Location: ...the burning end of the rope.
Ill have quite a few pics to download in a couple hours or so...
07-23-2011, 01:43 PM | #103 | |
RCC Addict Join Date: Sep 2010 Location: Malta, NY
07-23-2011, 05:51 PM | #104 |
Im waiting for the temp to drop a bit outside so I can weld the lockers up...Ill post pics and text as soon as I get some stuff uploaded.
07-23-2011, 06:18 PM | #105 |
| pics...and lots of 'em
here is the rear inner hole in the chassis side plate that had to be ovalled a bit to line up with the Ax skidplate...about 1mm. Upper and lower link set up...the uppers have a 2mm spacer at the chassis and are mounted flush at the BTL plate. The lowers are mounted to the axle between the tabs and there is a 7.5mm spacer at the chassis. Currently the straightened lowers are on the front...Ill switch that around and put the stock 2 bend links back on the front and put the straightened ones on the rear like I have my own...in the last pic you can also see the corrected C-hubs More in a few minutes |
07-23-2011, 06:26 PM | #106 |
| more.....
here are the pre-weld lockers Pin Lox on...Ill take the front axle apart real quick to replace the diff internals with a Lincoln Locker...the rear diff is apart and cleaned up and waiting for the LL. The servo and bec need new connectors soldered on before they are reinstalled Ill get pics of the servo and how much clearance there is with the new V2 BTL plate... |
07-23-2011, 06:42 PM | #107 |
cool man, shes looking great. sounds like u dont have very much more to do so im deffinalty looking forward to seeing her complete. |
07-23-2011, 07:03 PM | #108 |
| two more....
heres the 7955 sitting loose in the BTL plate. Theres about a 1/2" of clearance under the servo to the pinion. these are the last two pics for a bit..time to weld then back to building. |
07-24-2011, 04:54 PM | #109 |
OK..got a couple of issues Dalton....the XR is a soft sprung chassis by design...the red springs are just too stiff...whites or golds would be much better. You drive shafts are toast, the steel yokes are ok but the plastic shafts themselves are bad (the front one is about to let go at the yoke ears and the rear is tisted like a rifle barrel)...I can set the rig up but youll need to address these issues quick. A couple other things...your steel yokes were both loose at the transmission...I thought at first the diff was toast in the tranny then tried the yoke set screws and they were loose. Im workin on the link set up right now and getting hte shocks a little softer and getting the ride height down, right now its at over 3". Im close to getting the electrics back in, but have some connectors to redo. |
07-24-2011, 06:08 PM | #110 |
I bet with the c hubs backwards dalton had to use the stronger springs to keep the front wheels planted on turns uphill.
07-24-2011, 06:48 PM | #111 |
okay well, i have a set of losi white springs so if u set the preload i can go thought and change out the springs when i get it back. the hobby shop in colony on central ave is full of traxxas parts so im shure i can probly get a set of traxxas steel yokes and some traxxas long shafts to put in there also. that all must have happened when i put that new holmes hobbies motor in there. all that wheeling and crap like that |
07-24-2011, 07:12 PM | #112 | |
07-24-2011, 10:06 PM | #113 |
| first flex as a roller
FIrst flex shot as a roller...not done yet, but real close. |
07-24-2011, 11:07 PM | #114 |
| KICKASS shes looking great man, okay cool then ill get some traxxas long truck half shafts to fix it all up. |
07-27-2011, 06:47 PM | #115 |
| some updates...more coming
Heres some updates,,, Attention to detail/s...Dalton has a Holmes Hobbies decal on his Creeper Link and I of all people know how we feel about our favorite vendor's decals...one of the axle mounting screws is under the decal...so I cut around the screw with a razor knife and then removed the screw then reinstalled it...ya almost cant tell it came out.. The front lower links had a bit of a difference in the bends they had..might have been a bad hit to the front axle or the way they were bent... The Rooster Crawler ESC was relocated to a custom Lexan shelf on top of the transmission...the Rooster is velcroed and the top cross brace helps to hold it steady...the motor wires were shortened for better current flow and rerouted through a hole in the shelf...the CC BEC will go behind the Rooster on the shelf... This is the reshaped and cleaner mounted modified axle skid... Front shock mount.... Rear shock mount.... Here is better pic of the shelf with a Paradox Lincoln Locker sitting on it...two Axial straight rod ends without the pivot balls provided the shelf supports...this works well for tying wires up too.... |
07-27-2011, 07:24 PM | #116 |
looks good thomas! the links i think where a bad set cus ive been having a a problem with tracking from the beginning. when i got the new rear links thou, they were (to atleast my eyes) perfect. Did u have to end up shorting the longer front link to make them even? other wise looks great, i love that shelf over the trans. im saprised i didnt think about that. |
07-27-2011, 08:15 PM | #117 | |
07-27-2011, 09:16 PM | #118 |
okay cool, im so anty right now to see my rig in person when its all finished.
07-27-2011, 10:12 PM | #119 |
07-27-2011, 10:32 PM | #120 |
true, i would be driven my sprint 2 flux but last week the thing flipped and the upper a arm popped off the ball and then when i looked i saw that one of the axles went fling out as it was flipping so now its only 3wheel drive (really its 2 buy there are 3 axles in so) and i need to contach some of my LHS to see if they have one.
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/venom-creeper/314951-vcduds-venom-biuld.html | ||||
2.2 Venom Sportsman Creeper | This thread | Refback | 10-07-2011 10:58 AM |
