12-31-2011, 11:28 PM | #1 |
Rock Crawler Join Date: Nov 2011 Location: Paradise, ca
| The pig build
I bought this venom from a friend for 300 with a great deal of work done to it. Lets start with the all metal custom built chasis he made with adjustable link points and bug body. The electronics consist of of novac rooster crawler spec esc with lipo cut off a handwound 35 turn tekin motor and a jrracing z9100t steering servo and a protek 3000 nihm speed pack. Came with a onyx 210 charger a set of proline chisel tires a spare set of losi comp tires and stock creeper tires and the novac 55 turn motor. Also got some other odds and ends to go with like spare axle shafts and some miselance parts. now onto the picture i have of it please tell me what ya all think. Last edited by 89lxmorepower; 06-09-2012 at 08:33 AM. |
12-31-2011, 11:39 PM | #2 |
I wanna be Dave Join Date: Jan 2006 Location: ...the burning end of the rope.
| Re: So my first 1/10 crawler is a custom venom creeper
Sounds like you got a decent deal considering the parts list...some body off pics of the entire set up front, rear, both sides and event the bottom will make it much easier to help you with any suggestions...
01-01-2012, 12:34 AM | #3 |
Really not going to much on it lower shock mounts are in the lower links not on the axle differ are jb welded already so they are full time locked has mad flex to it just need to redo the shocks oil right now. But I will grab some body of pics in a day or two probally Tuesday when I do the shock oil. Biggest thing I wanna do are losi aluminum comp shocks and maybe some hb rovers. But it's a beast a heavy beast at 7.6 pounds.
01-01-2012, 12:46 AM | #4 |
the bats are a big part of that beast weight....flex wont be affected by shock oil only the speed at which it flexes...spring rates and angles will do more for controlling the flex...maybe limit the shocks if needed.
01-01-2012, 01:37 AM | #5 |
No problems with flex does quite well the shocks in rear are at full droop and fronts are at tightest point to keep cage off steering servo which has a shield and actually battery's not much of the crawlers weight at all. There's no plastic chasis left it's been all done with with like 1/4 inch rod maybe a little smaller diameter I'll get full body off pics later today and up load em for ya to see
01-04-2012, 08:24 AM | #6 |
Newbie Join Date: Dec 2011 Location: Illinois
nice first crawler!
01-04-2012, 11:27 AM | #7 | |
| Re: So my first 1/10 crawler is a custom venom creeper Quote:
01-04-2012, 04:33 PM | #8 |
Quarry Creeper Join Date: Nov 2011 Location: IN A HOUSE
cool creeper, sounds like a good deal ! |
01-16-2012, 07:31 PM | #9 |
Newbie Join Date: May 2010 Location: TORONTO
Yes very good deal, I already spent 500 on it.
02-26-2012, 11:52 PM | #10 |
Ya the chasis tubbing is smaller than 1/4 inch and with the battery it weighs in at 7.6 pounds
02-26-2012, 11:54 PM | #11 |
I will get current pics up soon of body off
03-10-2012, 11:53 PM | #12 |
so here is some more shots of my venom [/ Last edited by 89lxmorepower; 03-10-2012 at 11:57 PM. |
03-10-2012, 11:55 PM | #13 |
i got another set of axles coming with lockouts already installed so im going to swap rears and out board the upper links but anything else anyone thinks i should change
03-11-2012, 09:30 AM | #14 |
Saddle pack the battery and get it down on the front axle on either side of the servo...raise the servo higher and mount the tie rod to the tops of the knuckles
03-11-2012, 09:54 AM | #15 |
i dont know how to saddle pack the battery an dont see how i can move the tie rod to top of knuckle how would i raise the servo
03-11-2012, 09:56 AM | #16 |
also are you talking front or rear axle for tie rods and i cant really raise servo it hits from as it is now
03-11-2012, 11:34 AM | #17 |
So im trying decide best gearing for what i crawl on i need a little more torque from my novac 55 turn anmd rooster setup i had a 35 turn didnt like it traded for a set of axles i got coming so whats best way for mlore torque gear wise without loosing to much top end from my 55 turn
03-11-2012, 01:51 PM | #18 | |
03-11-2012, 06:59 PM | #19 |
ok so onto the battery saddle question and raising the servo what are the best options for that
03-11-2012, 10:34 PM | #20 |
If you dont want to actually raise the servo then flip the servo horn up and move the tie rod on top of the knuckles...then reconnect the drag link to the farthest knuckle from the servo horn center...the servo horn should sit at a bit of an angle toward the knuckle it is attached to to make up for opposing rotation of the servo horn and the knuckle...in other words the knuckle is horizontal and servo horn is vertical.... Use the stock servo plate and mark a piece of aluminum about 1.5" wide and around 5" long to make a new longer servo/battery plate...you need a space on the axle on both sides of the servo for the battery. If you have decent soldering skills then I would cut the wrapping off of the nimh pack and open it up...the cells are attached with folded metal tabs that are spot welded to the ends...they are thin and easy to tear away from the cells...then once you have 6 separate cells arrange them in 3 cell packs...put two cells side by side both positive up then glue the third cell negative up..glue the three cells together...repeat for the other pack...then solder tabs of short pieces of wire between the cells in each 3 pack so that you end up having an un-soldered positive and an un-soldered negative...set the two packs on the axle and measure the distance between them...cut a piece of wire about 2 inches longer then your measurement. solder one end of that wire to the negative on one 3 pack and the positive on the other three pack...you should now have a 6 cell saddle pack with out leads...the left over positive and negative cell ends get the battery leads for the esc... There are plenty of write ups on doing saddle packs from back in the day...such as it is...Google making saddle pack and you should find something pretty quick...if not let me know and Ill help you find a written tutorial with pics etc. Youtube might have a video or two as well. |
So my first 1/10 crawler is a custom venom creeper - Similar Threads | ||||
venom creeper custom candy paint | santa cruz crawler | Paint and Body | 11 | 02-02-2012 06:11 PM |
Venom Creeper Custom tube Chassis build | hippo008 | General Crawlers | 2 | 07-19-2011 09:08 PM |
My new Venom Creeper crawler | Axisdrummer20 | Videos! | 2 | 03-23-2010 02:35 PM |
