02-25-2012, 09:05 PM | #41 |
Quarry Creeper Join Date: Jan 2011 Location: murrieta
| Gotta do a little looking around for stuff bro. It easily states what it is on his product page. But... It's a prewired connector from your bec to servo to the rx. It brings power abd negative only directly from the bec to servo and then brings only the signal wire from the servo to the rx. Makes it so connections are easy and that you don't have to cut, solder or tamper with the servo or bec connectors. I have one on order myself. Sent from my iPhone 4 using Tapatalk |
02-25-2012, 09:30 PM | #42 |
RCC Addict Join Date: Sep 2010 Location: Malta, NY
| Re: Masonis1's project creeper
hey take a look at his website Rocky Mountain Designworks |
02-25-2012, 09:41 PM | #43 | |
Rock Crawler Join Date: Jan 2012 Location: st.louis
02-25-2012, 10:03 PM | #44 |
Lol, can't spell it out any better. Good luck with your build bro. Sent from my iPhone 4 using Tapatalk |
02-25-2012, 10:17 PM | #45 |
02-26-2012, 12:37 AM | #46 |
RCC Addict Join Date: Jul 2009 Location: Ontherocks
| Re: Masonis1's project creeper |
02-26-2012, 09:55 AM | #47 |
Good diagram, thanks.
02-26-2012, 01:06 PM | #48 |
okay, to go along with gottorque's photo, heres a pick of the actual piece. there's a descrition in the link i posted and in 28offroads's first post about. |
02-26-2012, 02:14 PM | #49 |
Which bec jack should i get, there are 4 choices. Also, im getting pinloxs.
02-26-2012, 05:22 PM | #50 | |
Quarry Creeper Join Date: Aug 2009 Location: Corner of get a map and F- off!
| Re: Masonis1's project creeper Quote:
Paradox BEC Jacks....these little plug and play units keep you from cutting wires or modifying your servo plug or BEC plug...just plug your steering servo in one jack...the BEC in the other jack then plug the single wire plug into your Rx....DONE! Hitec servo users should have a BEC Jack with a Negative Wire to the RX...some glitching has occurred with Hitec servos not having a negative wire between the servo and the RX...So please choose from the list below. $8.00 each or $12.00 for 2 with or without negative wire. Hmmm... do you want one? or two? Hitec servo? get the one with the negative... | |
02-26-2012, 05:43 PM | #51 | |
02-26-2012, 05:46 PM | #52 |
what kind of servo do u have? ill tell u which one to get
02-26-2012, 05:56 PM | #53 |
I have an exi and will shortly have a solar servo.
02-26-2012, 06:16 PM | #54 |
then u want the ONE that does NOT have the neg wire on it.
02-26-2012, 06:47 PM | #55 |
02-26-2012, 07:41 PM | #56 |
So ran the truck today, rebuilt my course. I have a steep steep hill climb with a piece of flat, smooth stone in the middle of the course. Really steep. Then i lifted some heavy stones into my good ole wagon and walked them home. So much weight i popped the tires. Oh well. But made the course better. Im happy with it. Im soon to be making some course markers from old mason jar tops. I just need to search how wide the gates have to be and set up a good course. Hopefully i can have my full 20 by 6 foot space filled with stone and logs for a lot of different ways to crawl through. The truck ran very well. Very pleased with the esc change. Has lots of wheel speed and good braking. Very happy with that. No problems with drive lines except i broke one of my outputs, no big deal. Going to get a bec, output and some other stuff soon. Busy weekend so i couldnt do much. But i love this crawler. Ckrc parts should be in soon. Then another test with the new ROVERS! Cant wait to see what i can do with those. |
02-27-2012, 05:31 PM | #57 |
Got some more money after selling a couple things, so i think i can get some more parts!
02-27-2012, 07:59 PM | #58 |
| Re: Masonis1's project creeper I have a bag full of tennis balls, cut in half that my boys and I use as gates. I believe the width is 16" for comp gates. Check the rules section in the competition forum. |
02-28-2012, 06:14 AM | #59 |
Ok thanks. Will anything that are 16in apart work?
02-28-2012, 11:16 AM | #60 |
| Re: Masonis1's project creeper Soda cans 16 in apart will work, it's up to you what you use. We use smaller markers because we may hover over a gate or hit a gate. Chalk is used under it to mark where it was for the next guy after it gets hit. A wooden dowel cut to the correct length is used as the measuring standard between the gates.
Masonis1's project creeper - Similar Threads | ||||
project creeper | santa cruz crawler | Venom Creeper | 218 | 08-19-2012 09:40 AM |
adale4130's creeper scaler project | adale4130 | Venom Creeper | 13 | 06-19-2010 08:50 AM |
Project C-10 Creeper | brianw | 2.2 Scale Rigs | 0 | 04-08-2010 01:00 PM |
Project Creeper | mastathug0 | Venom Creeper | 13 | 01-16-2010 09:40 PM |
project creeper input wanted | badtodabone | General Crawlers | 16 | 07-30-2004 02:47 PM |
