03-05-2012, 04:26 PM | #101 |
Rock Crawler Join Date: Jan 2012 Location: st.louis
03-05-2012, 04:27 PM | #102 |
03-05-2012, 05:34 PM | #103 |
| A picture says soo much. Got the traxxas yokes, and its almost ready to run. I need to let the locktite dry a bit then going to test in the dark. I cant wait to run this. |
03-05-2012, 06:14 PM | #104 |
Ok... I just tested it, wow, got through stuff i couldnt believe. Now the tires seem to bunch up and lock up underrocks. Should i use the foams that came with the rovers?
03-05-2012, 06:16 PM | #105 |
| Re: Masonis1's project creeper
Hey mason, still rubbing when you turn? I have read a lot of threads.. the best an most said idea is the link should be between the tabs an ur shocks closest to the center, inside the links.. have you tried that to get rid of rubbing ur tires? Just a thought from seeing ur pic.. still waiting for my traxxas shafts to show, :( losi shocks got here today tho! |
03-05-2012, 06:21 PM | #106 | |
03-05-2012, 06:54 PM | #107 |
Ok cool.. I just barely miss an I have my shocks between the tabs an my links in towards center. I just haven changed it cause I was waiting for my new shocks.. there here now! An yeah my problem also is the 6cell bats.. but I have a pile of them! An I'm spending my money else where first.. finding a charger will be before the lipos them selves.. I want a good multi bat charger then pick up a lipo here an there..
03-05-2012, 07:34 PM | #108 | |
| Re: Masonis1's project creeper Quote:
03-05-2012, 07:36 PM | #109 |
ok, new video coming soon. i know it should be in the wraith section but im outting it here because some of my creeper parts are on there. hah nothing much tho. this is my friend tommys crawler. i wasnt able to be there to record it so its kinda bad, i did my best to make it ok with editing. let me know when its up. Last edited by masonis1; 03-05-2012 at 07:36 PM. Reason: forgot something |
03-05-2012, 08:48 PM | #110 |
Ok couple things. Video is up on my youtube. Youtube.com/masonis1 now back to the creeper Plates have been painted. Looks good |
03-06-2012, 06:20 AM | #111 |
Today, going to mount the plates to the upper links after drilling holes for the wire ties im using. I tried running the big battery in a couple places, on the rear upper links, couldnt crawl up hills, on the front axle, pushed the wheels flat and was harder than hell to turn, i dont know where to mount it. To test i will just put in front.
03-06-2012, 10:33 AM | #112 |
Ok. Sorry if i ask too many questions that have been answered before. My next question is something im going to go search. But if i cant find an answer, here it is. Should i run the stock creeper foams with the rovers? They seem really soft up front with the weights too. The tires are flattening out a lot. But other than that, the truck is working good. I need te be able to steer more tho. Seems like with the rovers, the truck seems to just go straight when trying to turn.
03-06-2012, 11:35 AM | #113 |
Quarry Creeper Join Date: Jan 2011 Location: murrieta
The stock foams are better foams than what comes with the Rovers...but, the stock foams are too short for the Rover tires. Run the Rover foams untill you buy some upgraded ones.
03-06-2012, 11:53 AM | #114 |
03-06-2012, 11:55 AM | #115 |
03-06-2012, 03:37 PM | #116 |
RCC Addict Join Date: Sep 2010 Location: Malta, NY
go get yourself a set of the paradox dual disk foams. they are made to work with a tire that is 5.5in tall or the same height of the rover tire. they are cut in half already and the new style are star cut also |
03-06-2012, 03:44 PM | #117 |
I wanna be Dave Join Date: Jan 2006 Location: ...the burning end of the rope.
Star cutting foams causes soft spots in the tire..points where the tread isnt supported...Paradox Dual Disk foams are two unglued 1 inch thick disks per tire..each disk supports the tire more independently meaning that when one tire shoulder is being compressed the foam isnt being pulled across the inside of the tire. Paradox Dual Disk foams are NOT star cut...not by me anyway. |
03-06-2012, 03:50 PM | #118 |
And just a note about amps vs. volts... volts = power amps = length of time power is available amps have nothing to do with how much power you have...they only determine how long youll have the given power. |
03-06-2012, 03:58 PM | #119 | |
03-06-2012, 04:28 PM | #120 |
Ok cool. Well after talking to rmdw im going to make my own bec jack then im going to buy a btl kit and im gunna get my friends dad that has a foam cutter to cut the foams for the rovers in half until i can get something better I looked in the tire section and i found the star cuts benifit it, i guess that was good when no weights were in the wheels but when i added weight, it started to suck. |
Masonis1's project creeper - Similar Threads | ||||
project creeper | santa cruz crawler | Venom Creeper | 218 | 08-19-2012 09:40 AM |
adale4130's creeper scaler project | adale4130 | Venom Creeper | 13 | 06-19-2010 08:50 AM |
Project C-10 Creeper | brianw | 2.2 Scale Rigs | 0 | 04-08-2010 01:00 PM |
Project Creeper | mastathug0 | Venom Creeper | 13 | 01-16-2010 09:40 PM |
project creeper input wanted | badtodabone | General Crawlers | 16 | 07-30-2004 02:47 PM |
