Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Venom Creeper
Thread: Drive shafts for a venom Safari creeper?
Old 03-09-2012, 09:38 AM   #1
Default Drive shafts for a venom Safari creeper?
What is the best Replacement drive shafts for the SH**ty ones in the venom Safari Creeper?
hotwheels3 is offline   Reply With Quote
Old 03-09-2012, 11:01 AM   #2
Search is your friend...
Which drive shafts?
28offroader is offline   Reply With Quote
Old 03-10-2012, 07:15 PM   #3
Default Re: Drive shafts for a venom Safari creeper?
Here we go again........
Tips and tricks thread...STICKY..at the top pf the page..reading is fundamental.
TECH TIP 3 Change the stock drive shafts. Most of us use some sort of after market drive shafts. I personally recommend the Traxxas units. They are a bit pricey but you will save money in the long run if you don't have to keep buying parts. I use the Traxxas Hardened Steel Yokes,,,Part # 4628X, you'll need two packages of these for your rig, there are two yokes in each package. I also use the Traxxas Long, truck Half-shafts,Part # 1951, one package for the truck contains two male and two female shafts. part # 1953 is a Pro pack of the shafts which has 6 complete M/F shafts.
The Yokes are steel and should be installed with two set screws per yoke, and the shafts are plastic,,but trust me they are strong and will last a long time. I'm running the original set of shafts I installed months ago. At the very least,,,,Use Blue Loctite,,,on the set screws when you install the yokes to your transmission and axle out put shafts. Let the Loctite cure before you drive the rig or put it under power.
rmdesignworks is offline   Reply With Quote
Old 03-13-2012, 07:40 PM   #4
on my sons I used a set of mip shafts for the ax10 they ran a littel moore but he hasnt broke one and its been over a year now
lewlew is offline   Reply With Quote
Old 03-14-2012, 08:43 PM   #5
Traxxas metal yokes an long truck shafts!
winnerone23 is offline   Reply With Quote
Old 04-21-2012, 09:48 AM   #6
These shafts fit without modification or did you have to mod them a bit?
mgputer is offline   Reply With Quote
Old 04-21-2012, 08:19 PM   #7
The only issue with running drive shafts that dont break is that something else will...and the Traxxas shafts are a cheaper replacement then some other parts.
Old 06-22-2013, 01:37 PM   #8
Did u ever find any that fit ?
xjchase is offline   Reply With Quote
Drive shafts for a venom Safari creeper? - Similar Threads
Venom Safari Creeper stephen napier Tennessee 6 10-28-2011 05:15 PM
venom safari creeper stephen napier 2.2 Scale Rigs 2 10-20-2011 06:56 AM
Venom creeper safari Skier Newbie General 4 03-25-2011 12:29 PM
venom safari creeper Aaronb Venom Creeper 14 10-05-2010 09:03 PM
