10-10-2012, 05:26 PM | #81 |
Pebble Pounder Join Date: Mar 2012 Location: Carrollton, IL
| Re: Just got a Venom Creeper (my first rc) and have a little bit of issues
Can I get a low voltage cutoff for tva axial ae-1 esc
10-10-2012, 05:53 PM | #82 |
Can I get a low voltage cutoff for the axial ae-1
10-10-2012, 07:00 PM | #83 |
Maybe, prolly... Cheapest, easiest way to go bout it.. get a Lipo alarm.. like 6$... You can get them for up to 6s an with a voltage display on them..
10-11-2012, 03:26 PM | #84 |
Where could I get one of them
10-12-2012, 11:25 PM | #85 |
Shhh.. *bay.... Look up Lipo alarm.. |
10-13-2012, 11:49 AM | #86 |
Can I use this battery Turnigy 2200mAh 3S 40C Lipo Pack with this low voltage alarm 7.4V -11.1V RC Lipo Battery Low Voltage Tester Checker Alarm Indicator New | eBay Last edited by scoggdog13; 10-13-2012 at 11:52 AM. |
10-13-2012, 02:20 PM | #87 |
Yep, that will work for a Lipo alarm.. for a dollar or two more, you could get one that also has a led read out of ur voltage as well.. if you wanted.. I have alarms an a Lipo voltage checker. Cost twice as much as buying one that does both.. just a thought.. Yes, that battery will work. Suggestion.... Get 2x 1000-1300mah(turnigy Nano-tech is what I run) it saves on high up weight an lowers ur cog, an can be used if you ever go with a axle mounted battery setup.. cough cough, Rmdw btl kit.. lol.. it kills two birds with one stone.. ota steering, no more hanging up on the tie rod out front an cheaper upgrade.. saves ur servo from abuse an gets the battery on the axle.. |
10-14-2012, 09:25 PM | #88 |
Thanks ill have to look at those batterries and what kind of charger do u use with that
10-15-2012, 09:13 AM | #89 |
Quarry Creeper Join Date: Apr 2008 Location: SHADYSIDE
scoggdog13, you wanna go fast like a wraith but still wanna crawl, heres what i am runnin in my creeper, for 12 bucs get a hpi firebolt 15turn brushed motor,a 19 tooth pinion, a single outcry esc from 4wdrc you can run both 2 cell an 3cell lipos,i run both from a 800 to a 1600 get close to 30 minutes of run time depends on your trigger finger,i all so put a proline tuber cage on mine with roof rack give it a scale rock buggy look, on 3 cell 1600 it will smoke a stock wraith in a flat drag easily, just my 2 cents. caution!! faster means broken parts also.lol.
10-15-2012, 09:45 PM | #90 | |
| Re: Just got a Venom Creeper (my first rc) and have a little bit of issues Quote:
Sounds like a rally rock racer, not a crawler.. team drivers are running a 55t with a 19t pinion.. I can only imagine a 15t... Video? | |
10-16-2012, 06:17 AM | #91 |
| Re: Just got a Venom Creeper (my first rc) and have a little bit of issues I will see what my wife can do with her new camera then I will post it on here |
12-05-2012, 05:27 PM | #92 |
which lipo alarm would be better to use with this battery? 7 4V 11 1v RC LiPo Battery Low Voltage Tester Checker Alarm Indicator New | eBay 7V 14V RC LiPo Battery Low Voltage Buzzer Alarm | eBay Turnigy nano-tech 1000mAh 3S 45~90C Lipo Pack |
12-06-2012, 09:03 PM | #93 |
Are you just using it for a alarm? I have one that's a voltage checker with numbers, I like, an just a alarm.. since I have seen them combined into one.. nice numeric read out for testing batteries voltage an alarm when there low.. for 6$-7$... Other then that, either will work.. if ur never goin to use a 4s battery, the top choice is good.. |
12-25-2012, 10:29 PM | #94 |
I have a few updates havent posted in a while so bought this off of a member here on rccrawler.com on the for sale section. Had to do a few modifications to it but not much and still need nuts for the rear shocks because it is Christmas and the hardware store wasnt open today so here is the thing I have purchased I am using all the stock venom parts venom trans venom links and shocks, tires and wheels just different chassis which is a scx10 chassis will tubing on it. Also just ordered a axial 27t motor so should be here this week or next. Well thanks for looking and hope you like it. |
12-25-2012, 10:38 PM | #95 |
RCC Addict Join Date: Dec 2008 Location: pullin somebody else out of a mud hole
looks good always like to see the creeper being used for scalers as well as comp rigs
12-30-2012, 06:11 PM | #96 |
check out the video of my venom creeper Venom Creeper customizations and running video - YouTube |
12-31-2012, 02:14 PM | #97 |
Here are some pics of the new body, homemade scale accessories, new motor, and siped tires new motor siped tires scale accessories under the hood old body new body mounting what the new body use to be on the truck That is it thanks for looking and hopefully some rc4wd 2.2 tsl boggers are in my future Last edited by scoggdog13; 12-31-2012 at 02:23 PM. |
01-02-2013, 07:44 PM | #98 |
Well went out and drove the truck today and I noticed I didnt have any rear wheel drive so I checked it out and one of the drive pins came out and was stuck to the motor so i went inside and thought i fixed it and I put the pin through the big circle hole instead of the one it is suppose to go in well it locked up so i gave it some throttle and boom there went the drive shaft and i really dont have the funds for a new one at this moment |
01-02-2013, 11:40 PM | #99 |
That sucks! I knew the feeling once.... That's all it took to go a diff direction for a drive shaft. I went Traxxas shafts an metal yokea first.. then I realized I could get mip drive shafts for around 30$ used actually got em for 22$ or something.. someone sold ygm on ebay under junfac shafts.. lucky! Then got a set on the for sale section for 25$.. worth every penny of retail! 60$... Last a life time! Haven had one single issue since.. good thing too, cause I got no funds to replace either..
01-03-2013, 02:55 AM | #100 |
ahhh S^*T Join Date: Mar 2012 Location: in the shop bending metal in Whatcom Co. WA.
hey bud PM me about some parts for your rig. looks like you can use some good driveshafts.
Just got a Venom Creeper (my first rc) and have a little bit of issues - Similar Threads | ||||
Venom Creeper Safari Front Driveshaft issues | xxROELKEYxx | Venom Creeper | 24 | 02-05-2012 07:33 AM |
venom torque twist issues | gsmall | Venom Creeper | 6 | 03-19-2011 07:52 PM |
Safari creeper issues | THEDUDE79 | Venom Creeper | 0 | 03-04-2011 07:28 AM |
New Creeper build issues - Not very good QC at Venom... | rwkhaussupply | Venom Creeper | 15 | 01-19-2010 06:56 AM |
Bit confuessed about the creeper. | MATT01234 | Venom Creeper | 4 | 11-06-2009 02:08 PM |
