07-09-2012, 11:19 AM | #1 |
Rock Crawler Join Date: Jan 2012 Location: Mcallen, Tx
| Creeper Wheel Widener? whats the best wheel widener for creeper axles, i hate that i cant run my mayhems or any other wheels other than my creeper wheels, anyone have a link or a brand/model i can search for? need em asap for a comp om the 21st thanks! |
07-09-2012, 04:17 PM | #2 |
| Re: Creeper Wheel Widener?
I have some Berg offset wheels on my creeper. I bought a multi sized HR widener kit. Modified the 5mm spacer to work between my pin an hex.. tho there are easier ways I'm sure.. depends on how wide you want to go.. it comes with a 10mm an 15mm.. the 15mm takes the pin thru it an holds ur hex on.. I didn't want to be that wide. Now with the 5mm spacer on, I'm out 12mm from knuckle to end of hex.. 17mm out with the 10mm spacer an the main "15"mm widener, puts it out 24.5mm... So lots of choices but also, I think, 38+ dollars.. but I needed it at the time... An has been on for 5 months or better.. thru two comps, crawling a few times a week an dig!
07-09-2012, 04:55 PM | #3 |
Quarry Creeper Join Date: Jan 2011 Location: Kyle TX
Interesting, I've run every wheel I own but the creeper wheels. JunFac makes a 12mm widener. Wheel Wideners : JunFac.com RC4WD has some also. |
07-09-2012, 07:38 PM | #4 |
I wanna be Dave Join Date: Jan 2006 Location: ...the burning end of the rope.
Some plain old G-Made red wheel wideners should work for the BERG offset just fine...
07-10-2012, 07:53 AM | #5 |
thing is i have xr wheels and mayhems and they dont fit because of the knuckle but ill check out the gmade ones,
07-10-2012, 01:36 PM | #6 |
RCC Addict Join Date: Sep 2010 Location: Malta, NY
what mayhem wheels do you run? i have the MAYHEM ENG. DP wheels on mine. there are a couple of guys that run axial XR10 wheels but they either had to cut and narrow or they used the wideners. you have to run axial offset wheels to get the wheel to work with the knuckle design
Creeper Wheel Widener? - Similar Threads | ||||
wheel widener help | ped453 | Losi Mini-Rock Crawler | 5 | 08-12-2009 12:22 PM |
Which wheel widener to get? | nova801428 | Tamiya TLT Crawlers | 7 | 07-11-2006 03:00 PM |
Wheel widener ??? | Family Guy | Tamiya Clod Buster | 4 | 02-01-2006 01:55 PM |
wheel widener... | bobnom | Tamiya Txt-1 and Juggernaut | 7 | 07-04-2005 11:11 AM |
