02-21-2013, 06:37 PM | #1 |
Newbie Join Date: May 2006 Location: WOODBRIDGE
| Cvd rebuild help
I have a set of creeper axles that I want to use on a project but my front axle is missing the parts of the Cvd that join the two axle parts together......the little pin and the piece it slides into...not sure of their exact names. Does anyone know where I can find these parts?
02-21-2013, 09:20 PM | #2 |
Well... Cheapest route, if you have access to A welder or know a welder.. pull ur rear axles out, make a jig, lay the axle shaft an stub shaft into the jig an weld em together. Making sure they stay straight.. the you have locked rear straight axles an use the rear axles up front... BAM
03-26-2013, 01:29 PM | #3 | |
Newbie Join Date: Jul 2012 Location: Mifflintown
| Re: Cvd rebuild help Quote:
For the pin..i used either linkage rods for rc airplanes 2-56 diameter works in mine..and have used broken drill bits of the same diameter just cut them to length with your dremel cutoff wheels.. | |
03-26-2013, 03:31 PM | #4 |
RCC Addict Join Date: Jun 2011 Location: Lindsborg
the collar can be replaced with heat shrink. there are 5 total pieces to one CV, do you have the Ferrell that the pin goes through inside the ball? it is threaded and you can run a small set screw in to hold the pin if you don't want to run the collar.
Cvd rebuild help - Similar Threads | ||||
CVD Rebuild? | Man of 5lay | Venom Creeper | 14 | 06-07-2011 10:22 AM |
CVD Rebuild kit for creeper information here! | Twiztid Metal | Venom Creeper | 1 | 06-03-2011 03:26 PM |
cvd rebuild help | goobs | General Crawlers | 4 | 01-17-2011 09:27 PM |
MIP CVD rebuild kit? | av8rds | Team Losi Comp Crawler | 4 | 11-14-2009 10:06 PM |
