03-24-2014, 03:32 PM | #1 |
Newbie Join Date: Feb 2014 Location: Brookfield
| New rig to my fleet.
Just added a Creeper to my fleet!! Was wondering what things I should look out for upkeep and what weaknesses it might have. Running gear is a Novak Rooster Crawler esc and Goat 45t motor. It has HR lockouts, c hubs, and knuckles. HB Rovers on stock beadlocks. Equiped with DIG. Any opinions or statements??
03-24-2014, 05:50 PM | #2 |
RCC Addict Join Date: Jul 2009 Location: Ontherocks
| Re: New rig to my fleet.
Congrats on the purchase. Creepers are a great platform (have been running Creepers for years and cant get rid of them, lol) First thing is to pull it apart and give the diffs and trans a good clean and re grease. That way you can check over everything to make sure nothing is broken or damaged. Have a read through this thread. A ton of good information about the Creeper about fixing its weaknesses and rig set up RMDW T's & T's & set up. If you have any specific issues, post up and Ill help you out |
03-24-2014, 07:06 PM | #3 |
Thank you sir. Have a Wraith but wanted more of a crawler. Miss my ax10 but I like this a lot better.
03-24-2014, 08:38 PM | #4 |
Rock Crawler Join Date: May 2007 Location: Arnold
The front axles are a weak point, To my knolegde there is no drop in fix for them. like gottorque said read the tips and tricks section. A lot of the build threads have a lot of helpful info also.
03-25-2014, 03:50 PM | #5 |
There are cvds. They have a gold retainer ring for the cvd pins??
03-25-2014, 04:26 PM | #6 |
RCC Addict Join Date: Dec 2008 Location: pullin somebody else out of a mud hole
sounds like you have the stock cvd's with rmdw pin locks on them , alot of the issues with the axle shafts has been breaking due to mis-heat treating ( which shouls have been resolved with the later axle shafts ) welcome to the creeper sicness , i myself have several creepers either axles or complete drivetrains . as was stated earlier read the rmdw tips and tricks section for alot of good advice on the creeper |
04-02-2014, 07:24 AM | #7 |
Quarry Creeper Join Date: Sep 2005 Location: LRAFB
to main gripes for me first drive shafts i have now went traxxas for that next is no metal gears for the giant gear box for most its not a problem but i drive mine like its a wraith and want to go brushless but haven't because of this |
04-02-2014, 07:01 PM | #8 |
| Re: New rig to my fleet. get an axial trans for it. far easier to work on and parts are readily available
04-07-2014, 06:13 AM | #9 |
I have thou about that but just needed up buying a axial lol
04-18-2014, 05:21 PM | #10 |
Which traxxas driveshafts?? Maxx series??
04-19-2014, 09:06 AM | #11 |
I use the Traxxas Hardened Steel Yokes,,,Part # 4628X, you'll need two packages of these for your rig, there are two yokes in each package. I also use the Traxxas Long, truck Half-shafts,Part # 1951, one package for the truck contains two male and two female shafts. Per the tips and tricks Make sure you get the the steel yokes the plastic ones don't work |
New rig to my fleet. - Similar Threads | ||||
The tracked fleet | Gumbajv | Non Crawler RC's | 4 | 02-01-2014 07:08 PM |
My fleet | 90DEGREES | Chit Chat | 4 | 11-24-2005 05:13 PM |
My fleet | mattallica | Chit Chat | 28 | 10-05-2005 07:42 AM |
