Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Venom Creeper
Thread: Axle pinion
Old 07-21-2019, 07:54 PM   #1
Default Axle pinion
The pinion gear stripped on the Venom rear axle in about 2 minutes - give or take a few seconds. Extremely poor material/quality. Out of production and no one has 'em.
A guy recommended I try the Axial AR44s. They work GREAT. Just wanted to pass along in case anyone else has their machine sidelined for the same reason.
I got 'em at Tower Hobbies. You will need 2; 1 front and 1 rear.
LXGDJL Axial AR44 Locked Axle Set Front/Rear Complete 1 $67.99
Bought the Axle Servo Mount at AMain Hobbies.
1 x BPCSM2 BP Custom SCX10 II AR44 Servo on Axle Mount $9.99
falcon_az is offline   Reply With Quote
Axle pinion - Similar Threads
Axle pinion shims Levi RC4WD Trail Finder 2 5 05-24-2017 10:04 PM
Axle spitting out pinion rkates Team Losi Comp Crawler 6 03-08-2011 11:11 PM
Axle pinion angles SteepJeep Tamiya TLT Crawlers 7 08-20-2005 10:06 PM
