08-07-2014, 08:58 PM | #1 |
I wanna be Dave Join Date: May 2007 Location: Fairfield ME
| Is it legal for the bealock bolts to pass through the tire? Glue on questions too...
Is it legal for the beadlock bolts to pass through the tire? Must they be below the bead? The rules aren't clear (to me) about this. Also are we allowed to glue the tire to the wheel at a larger od than of that the bead? |
08-07-2014, 09:48 PM | #2 |
| Re: Is it legal for the bealock bolts to pass through the tire? Glue on questions too
I think the bolts through the bead should be legal as long at they don't break the max outside OD ring requirement.
08-08-2014, 11:39 AM | #3 |
I wanna be Dave Join Date: Aug 2007 Location: JERSEY BOONDOCKS
There is a lengthy debate going on right now in the rules committee regarding this same subject. Please stand by for an official ruling on this.
08-08-2014, 01:54 PM | #4 | |
| Re: Is it legal for the bealock bolts to pass through the tire? Glue on questions too Quote:
There isn't any limitation on peircing the bead. As long as the bead can sit at 2.2"ID. The limits for external bead rings is 2.55" OD. From bead to bead internally there is not a restriction, but if there is only an internal bead mount then it must meet the 2.2" or smaller restriction at the bead. This is how I would look at a plate design with "floating" bead beds that didn't have a lip in the radial direction. The side plates are the only point for bead attachment, so it has to hit the defined values by ID instead of traditional wheels where it is OD. | |
08-08-2014, 03:50 PM | #5 | ||
I have tried veiwing your picture on two different browsers with no luck. Any suggestions on how I could view it? | ||
08-08-2014, 03:54 PM | #6 | |
MODERATOR™ Join Date: Jul 2004 Location: Ohio
http://www.rccrawler.com/forum/attac...3797-image.jpg Says I don't have sufficient privileges, as I can't see the Rules Forums (thankfully). | |
08-08-2014, 04:30 PM | #7 |
Zzz
Is it legal for the bealock bolts to pass through the tire? Glue on questions too... - Similar Threads | ||||
tire glue | Diesel demond | Tires and Wheels | 7 | 06-18-2013 05:42 PM |
tire glue | losiminicrawler | General Scale Talk | 1 | 11-27-2009 11:16 PM |
??? Tire glue ??? | PIMPNROCKS | Tires and Wheels | 7 | 11-27-2007 10:45 PM |
tire glue | rash_powder | Tires and Wheels | 2 | 01-14-2007 12:06 PM |
tire glue | Savageking68 | Newbie General | 5 | 04-25-2006 10:15 PM |
