Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > XTM Crawler
Thread: Question for DirkDigler
Old 03-02-2004, 07:16 PM   #1
Default Question for DirkDigler
How do you have your steering servo mounted on your electric X-Factor? Is it homemade or store bought?
NeoSlayer888 is offline   Reply With Quote
Old 03-04-2004, 10:33 AM   #2
Default Re: Question for DirkDigler
home made
DirkDigler is offline   Reply With Quote
Old 03-04-2004, 10:41 AM   #3
if you started a post for dirk question can you make an article of how to narrow TXT wheel so monster GT tires will fit the best on them
please please please
bar
bar-txt1 is offline   Reply With Quote
Old 03-04-2004, 02:06 PM   #4
Not sure what you are asking bar txt?
The tire article is up on the home page.
Are you asking for an acticle on how to make servo mounts?
Old 03-04-2004, 02:09 PM   #5
Neo
you are going to have to make it to one of local crawls!
for more detail about the servo mounts: I used the stock servo mounts that the X came with, cut them up and bent them to a 90 degree angle, upward. They work great. I then made small skid plates that mount under the servo mounts.
Old 03-04-2004, 02:48 PM   #6
i was talking about that you make an article-"how to narrow TXT wheels on the best way"
and if you can make some good/big pictures of your servo mount with servo and without servo it can be nice :o
bar
Old 03-04-2004, 02:54 PM   #7
just cut the outter rings off. It's easy. You can also see a pic of the rings cut off in the TXT article.
Old 03-04-2004, 03:04 PM   #8
ok
i will have a look on this
and the servo mount
can you give good pic's of it?
bar
Old 03-04-2004, 03:11 PM   #9
I'll do what I can for ya!
Old 03-04-2004, 03:28 PM   #10
:o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o
thanks
bar
Old 03-05-2004, 07:08 PM   #11
I wanted to be at the breakfast and school grounds but had FIRST robotics. FIRST robotics is done for now so I should have some fee time. I want to see your course in Pueblo. I would also like a good picture of your steering setup.
