01-20-2009, 06:14 PM | #1 |
Pebble Pounder Join Date: Nov 2008 Location: Plymouth
| XTM X-crawler setup questions
My wife got me the X-crawler for X-Mas and I'm finally getting around to building it. I got 2 quark 33 esc's a couple of 11.1v 2200 mAh lipos a Castle Creations BEC, couple 200 oz/in servos which im sure ill be upgrading... 2 Holmes hobbie torque master sport 1000kv brushless outrunners, and a AR6100 reciever. I was wondering if anyone had any ideas on what pinion gear to use and if its 48p ?? do I use an 8 tooth or like 12 ?? and any other setup tips would be helpful. i plan on setting up left stick for front axle fwd/rev and steer and right stick for rear drive and steer, and using some mixing or maybe flaperon to lock the drives so i dont have to freewheel all the time not sure yet. so any input on that would help to.. thanks! OH ps my radio is a DX7 |
01-21-2009, 08:53 AM | #2 |
Rock Stacker Join Date: Oct 2008 Location: debary fl
| sonford FL the place to rock
me and my friend have xtm crawler we use 8 pinion gear work great ,we also use airtronic rds 8000 is an 8 channel radio for heli but we converted to crawler work great rear steering separated or combo 2 esc 2 batteries one battery for each axle one esc for each axle 4 wheel steering or separted steering for each axle that where u program the controler ,we used novak goat brusless motor,noslipping if u need more help write back |
01-21-2009, 08:56 AM | #3 |
| sonford FL the place to rock |
01-21-2009, 10:07 AM | #4 |
is the 8 pinion gear 48p? Nice looking crawler... are you running 3s batteries ? can you post a pic of it with the body off ?? what KV brushless motors are u running ?? thanks!! cant wait to get mine going.. just waiting on parts now. i hooked up my radio last night and got my front and rear steering programmed and soldered the ends on my esc's just waiting on the motors and pinions.. |
01-21-2009, 11:49 AM | #5 |
Quarry Creeper Join Date: Aug 2007 Location: Pacific Northwest
That is one clean X-C................ Here is mine. |
01-21-2009, 07:51 PM | #6 |
Rock Stacker Join Date: Dec 2007 Location: Crawlarado
01-21-2009, 08:18 PM | #7 |
LOL will some one tell me if the pinion is 48p or not ??? haha....
01-21-2009, 08:47 PM | #8 |
I believe they are 48.
01-22-2009, 04:26 AM | #9 |
Quarry Creeper Join Date: Nov 2007 Location: in the shop, of corse!
Set up question.... Answer... Set it up on a shelf ...cause thats where its gonna sit |
01-30-2009, 07:55 AM | #10 |
T9dragon Or Gadge, I have the roosters crawler esc's with the 55 s. What motors are you running? I have no wheel speed are you useing stock pinion that the crawler came with ??? if not what pinion are you useing??
01-30-2009, 10:37 AM | #11 |
i am using (2) 65t integy's with stock gears,crawler esc's ..and yep its sloooooow. |
01-30-2009, 10:51 AM | #12 |
I am running dual Black Revolver brushless motors with the stock pinions. Here is a link to some videos of my X-Crawler. http://www.youtube.com/user/t9dragon |
01-30-2009, 09:17 PM | #13 |
do you guys know the hex size on the x crawler rim
01-30-2009, 09:19 PM | #14 |
01-31-2009, 06:00 PM | #15 |
Quarry Creeper Join Date: May 2008 Location: Federal Way/Tacoma
| x-Crawler servo question I have a question on my x-Crawler... Is a 200oz HighTorque servo strong enough for the crawler....? |
02-01-2009, 03:38 AM | #16 | |
The HSC-7955TG is the powerhouse of the bunch and was specifically designed for use in large monster trucks like the Traxxas T-Maxx, & REVO, Associated RC10MT, Losi LST, Large scale aircraft, 1/5th scale buggys and trucks, Large scale boats and anything that needs TONS of torque! Features: 4.8-6V Operation Operating Speed to 60 deg 0.15 seconds 333 oz/24KG of Torque at 6V Size 40x20x37mm Coreless Carbon Brush Motor All Titanium Metal Gear Drivetrain this is what im using x 2 front and rear steer | |
02-02-2009, 03:47 PM | #17 |
x2^^^^ i am using the HSR-version..same tq specs,with 180 degrees of travel.. it comes in handy |
02-03-2009, 01:26 PM | #18 |
02-04-2009, 06:19 AM | #19 |
Newbie Join Date: Jun 2008 Location: atlanta
| Just my $.02....
I don't know the pinion size, and would be interested in that myself. I'm running dual sidewinders pushing 65turn motors with a 9.6v pack, and have no wheel speed either. For servos I had to go to the Hobbico 333.oz. The 200.oz servos I had couldn't get the job done. The Hobbicos still struggle on occasion, but they seem to work. The biggest issues I have had with the truck are the tires, and the lower shock clamps. I found that the tires just don't grip and want to slide sideways on the slightest incline. The lower shock clamps would catch on everything I tried to climb over. I have some Imex rubicons on the way to help with the tire issue. I had really good luck with the smaller size version on my Axial. I am hoping these will work as well as those did. For the shock issue, I bought some HPI Savage shocks that are almost twice the length of the stock shocks. This put the lower clamps down within the diameter of the tires and now the tires will always hit before the clamps do. So far they seem to have done the trick. The articulation hasn't really changed as it seemed the original shocks allowed the chasis to articulate to the limits of the links. Other than those two issues, I have been happy with the rig so far. A little more wheel speed would be nice, but it still performs well as is. |
02-04-2009, 09:36 AM | #20 |
Are you using one battery to power both ESC's?
