Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > XTM Crawler
Thread: inner axle gear problem FIX!
Old 03-12-2009, 07:32 AM   #1
Default inner axle gear problem FIX!
well i made a fix on the steel inner axle gears that worked awesome last week. how i did it is removed the gears from the axles, press the inner gear which is too easy, clean with acetone, soak in coke or a solution of 50% hydrogen peroxide and 50% vinigar and let soak over night. next sand affected area on the gears, press back in, tig weld the back side then sand flush. you might have to re drill the end of the gear if the weld weeped into it. you could also braze. ive been running these gears for about 12hrs of hard use with no problems.
revo-4tec-mike is offline   Reply With Quote
