Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > XTM Crawler
Thread: XTM Crawler wheel adaptor
Old 06-16-2009, 01:10 PM   #1
JJR
Default XTM Crawler wheel adaptor
Does anyone know ho makes a wheel adaptor from 14mm to 23mm for the XTM Crawler?
JJR is offline   Reply With Quote
Old 06-16-2009, 04:11 PM   #2
YOu could use these http://rcpcrawlers.com/product.php?p...&cat=20&page=1
Just use 12mm hex's and then you will be able to use the RCP 12/23mm adapters!
Thats what i used and so far so good!
KRAWLR4life is offline   Reply With Quote
Old 06-16-2009, 05:47 PM   #3
Double check your stock hexes, my X came with 17mm. If I were adapting to 23mm I'd look at something like these.
http://www3.towerhobbies.com/cgi-bin...&I=LXJGR4&P=ML
John82601 is offline   Reply With Quote
Old 06-16-2009, 06:32 PM   #4
JJR
What about the hole on the adapter will that fit on to the axle shaft.
