Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > XTM Crawler
Thread: Motor Choice 45t or 55t??
Old 07-13-2009, 09:07 AM   #1
Default Motor Choice 45t or 55t??
I'm about to build my X-Crawler and wanted opinions on motors. I'm either going to go with a Single FXR or Sidewinder ESC and want the option on running on 3s Li-Po. Any idea the amp draw on either motor setup??
Thanks Chris
cmacclel is offline   Reply With Quote
Old 07-17-2009, 07:04 AM   #2
Motorama Bound
EvilTwin v2's Avatar
I'd head straight to a handwound 35t...especially if you're going to run the stock 8t pinion.
I used a set of these to replace the axle on our clod based super, and they're geared considerably lower than the clod.
I'm currently running a pair of Holmes Hobby Crawlmaster 1000kv brushless motors on them, each with their own 3s Lipo and Sidewinder ESC. In my opinion, they still need more wheel speed.
EvilTwin v2 is offline   Reply With Quote
Old 07-26-2009, 06:35 PM   #3
novak 55T or integy 45T
corychapman is offline   Reply With Quote
Old 07-28-2009, 05:55 PM   #4
We're running a pair of 55t Integy's on 3s and it is quite slow. To do it again I'd run 45t minimum and definitely take a look at 35t if you're used to a crawler with wheelspeed.
John82601 is online now   Reply With Quote
Old 08-28-2009, 12:23 PM   #5
I'm trying to stick with one ESC if I go with 35t's I'd need 2 or will a MM work with 2 35t's?
Mac
Old 08-28-2009, 12:39 PM   #6
Motorama Bound
Mac
It'll be fine.
My buddy is running 2 HH 35t's on his Sidewinder with no heat or other issues.
Old 08-28-2009, 07:50 PM   #7
55T is too slow so I did rewined to 40T but not fast what I want it..
I think 35T even lower ok because gear 50 to 1
ke6geu is offline   Reply With Quote
