Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > XTM Crawler
Thread: Maxx Sliders
Old 01-30-2004, 07:49 PM   #1
Default Maxx Sliders
I just picked up everything I need for the maxx sliders convertion. I was gonna do a write-up with pics. I wanted some opinions before I start.
It seems that to get the output yokes to fit onto our trannie shaft, you have to grind one side down flat to match the other, then drill a hole in the side for the screw. If anyone has any other meathod, please let me know.
The pinion shaft is larger than the output yokes. I'm wondering how you all went about this. Did you grind down the pinion shaft, or drill out the output yoke. Then of course a hole will have to be drilled in it.
Don't get me wrong I can figure this out, I just want to hear how others have gone about it. Other than modifying the trannie shaft and pinion shaft it seems to be pretty strait forward.
Thanks in advance
Jobu is offline   Reply With Quote
Old 01-31-2004, 09:03 AM   #2
Default Re: Maxx Sliders
On my truck I took pinions from the Savage which is all ready drilled and ground down where the teeth hit the diff cup. After that all you need to do is drill out the output yokes to match the pinion shaft.
Rockraider is offline   Reply With Quote
Old 01-31-2004, 10:42 AM   #3
I'll have to check that out, unfortunetly Savage pinion gears are on a mass backorder, my freind with a savage has been waiting over a month for em.
Old 01-31-2004, 12:02 PM   #4
Got the trannie shaft done. Very easy. A drill press is a wonderful tool. Hardend steel nothing. Hopefull the pinions will be the sameClick the image to open in full size.
Old 02-01-2004, 01:56 PM   #5
Oops forgot to log in. Can you email me at neoslayer888@hotmail.com when you finish your write-up please?
NeoSlayer888 is offline   Reply With Quote
Old 02-02-2004, 10:47 AM   #6
binaryterror's Avatar
Jobu:
I too await your article, hopefully with pics and the like.
Also a test of those sliders would be great...
binaryterror is offline   Reply With Quote
Old 02-02-2004, 02:38 PM   #7
Cool, it's good to know that some are interested. I'm about halfway there.
I haven't quite figured out the brakes yet. If anyone could help it would be greatly appriciated
Old 02-02-2004, 03:35 PM   #8
Use the TMAXX hub and disk. It mounts right on the tranny diff yokes.
This is OUTLAW's list:
Brake Calipers
Brake Rotor
Brake Adapter
Transmission Yoke
Slider Shafts
Old 02-02-2004, 04:38 PM   #9
The problem is that the traxxus brake disk is too large, it hits the bottom of the brake lever mounting screw. So I have two options as i see it:
One cut down the traxxus brake pad so it dosen't hit the screw, or grind out the inside of the stock x-factor brake disk so it will mount on the adapter hex.
As of now I'm putting it together without the brakes, to get all the suspention geometry right, also debating if I want to run Savage shocks or XTM shocks.
I also have two different set ups on the pinion shaft, and I want to see which one will work better.
This is quite a project, but I'm enjoying doing it, way more fun than a bolt-on kit.
Old 02-03-2004, 01:32 PM   #10
i had bill at rcalloys simply turn down the pinions on the x-factor axles to emaxx dimensions to fit stock maxx yokes.
it wasnt too expensive, but he says they were fairly tough to do.
badhoopty is online now   Reply With Quote
Old 02-08-2004, 11:13 PM   #11
Default Re: Maxx Sliders/ Some progress pics
Here are some pics of my preliminary built up. Started school two weeks ago so my free time has all but disapeared. So this is takeing some time to finish.
It's 17" from axel to axel and 21" with the big joes on. Also fabbed up a skid protecter for the front servo.
Old 02-23-2004, 12:24 PM   #12
well i am happy to report, that the t maxx sliders are still holding up great...
OUTLAW is offline   Reply With Quote
