Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > XTM Crawler
Thread: XTM axle swap???
Old 03-18-2004, 04:48 AM   #1
Default XTM axle swap???
I have noticed that XTM has a Axle swap now, they have the actual swap then below they have the 14 mm hexs that you can purchase. Does the axle swap aready have the 14mm hex in them or do you have to purchase them seperatly?
The way I am reading it is confussing me for some reason????
http://www.hobbypeople.net/gallery/146110.asp
http://www.hobbypeople.net/gallery/146114.asp
It says replacement but im still confussed.
shadow is offline   Reply With Quote
Old 03-19-2004, 09:56 AM   #2
Default Re: XTM axle swap???
I believe it comes with the stub axles, pins, hexes and nuts.
DirkDigler is offline   Reply With Quote
Old 03-19-2004, 11:11 AM   #3
binaryterror's Avatar
Yup you get the pins, buts, axle stubs and the hexes.
The part number for the hexes is for if you wanted replacements.
binaryterror is online now   Reply With Quote
Old 03-20-2004, 01:03 AM   #4
XFACTOR's Avatar
yep i have them, u get the hexes, pins and outdrive axles..!!
and they look nice
bt.. what are buts?? :?
ryan
XFACTOR is offline   Reply With Quote
