| | #1 |
| Newbie Join Date: Sep 2009 Location: a hole
| Is anyone running two Tekin FXR ESC's? I am am having problems getting the two to work together. Whenever you go from Reverse to Forward you have to stop and wait a second for them to flash a couple of times then you can go Forward. If you go from Reverse to Forward only the front will go. any help or suggestions. I am running a Rds 8000 radio, and one battery. i am new to this so any help would be appreciated. Thanks |
| Sponsored Links | |
| | #2 |
| Rock Crawler ![]() Join Date: Sep 2008 Location: Delta B.C.
| hmm, are you running each esc on a seperate channel..not familiar with your radio..do you have the tekin hotwire for programing..sounds like you need to program out the reverse delay in one or both..maybee different setup on each esc,..forward only on one? they are pretty easy to program if you dont have the hotwire..what mtrs are you running? i run tekins in my berg and they perform very well..once you get the programing sorted out you will be happy Last edited by vonclod; 09-15-2009 at 12:20 AM. |
| | #3 | |
| | #4 |
| cool, hope you get it up and running. |
| | #5 |
| Back in the WATER! ![]() Join Date: Mar 2008 Location: Pacific Ocean
| Make sure you have calibrated them both to your radio. There is a reverse delay that can be set as a % using the hot wire. So getting it is a good idea. |
| | #6 |
| Pebble Pounder Join Date: Feb 2009 Location: Pollock Pines
| Don't know if you have figured your car out yet, but it sounds to me that you just need to set the delay on your fxr. |
| Thread Tools | |
| Display Modes | |
