12-24-2005, 12:02 PM | #1 |
Newbie Join Date: Nov 2005 Location: Salem
| X-Factor Crawler :: My First
First time poster here, so howdy. I have been into RC for quite a long time. I currently Race Sedan Carpet track. However, being into Rock Crawling in real life (Images Here: http://www.networkconcepts.org/galle...Action+Gallery ) I thought I would build an RC Crawler. The Crawler below I built as a X-Mas gift for my best friend. He has never owned an RC Car and I thought I would break him in right. The Ride: X-Factor Gas Truck Converted to Electric. Stampede Trans - Locked. Composite Arrow Shaft Links Wheel Base = 17.0" The ride could use some more mods, including bead locks, bigger tires (narrow) and more. However this is for someone and not going to be mine so I thought I would leave some of those things for him to do. More images can be found here: http://www.networkconcepts.org/RC Here it is: If you are thinking about starting another Crawler project, I highly recommend the X-Factor as a starting point. The axles on these are great imo. I am also really happy with the stampede trans. I will right up more information later about the truck, and some of the custom things I had to do to get this thing rolling. |
12-31-2005, 11:48 AM | #2 |
Pebble Pounder Join Date: Dec 2005 Location: Knoxville
i have an x-factor and as a gas truck it isn't worth a damn...but this looks like a good idea...how did you get the revo shafts to fit the x-factor axle grub it's huge nice rig and good idea! |
12-31-2005, 05:15 PM | #3 |
Looks like a good start
01-03-2006, 04:04 PM | #4 |
Revo Shafts were pretty easy. 1. Drilled out the hole on the Revo shaft to fit the X Pinion Shaft. 2. Drilled the X Pinion shaft so that the "pin" would go through the revo shaft and through the pinion shaft. NOTE: There is a "hardened coating" on the pinion shaft for the xfactor axles. You have to either use a high speed drill or grind off the coating. I love the axles on the X-factor. The width is really nice, and the whole thing is really well built. |
01-13-2006, 04:12 PM | #5 |
thx for the tips...converting the xfactor is my next project right now i am working on a pti goliath...it's taking alot of time i just started classes again |
01-20-2006, 01:22 AM | #6 |
Rock Crawler Join Date: Nov 2005 Location: dallas
| small world, this is jim from dallas do you have plans to build youre own crawler ? if so bring it to portland for the next comp. http://www.orcrc.com/ heres my crawlercomp style tlt (GROUNDER) with front digg |
01-20-2006, 01:50 PM | #7 |
Pebble Pounder Join Date: Dec 2005 Location: Somewhere in Sweden
No, the world is big DonkeyWorx, your X-Factor looks good! |
01-20-2006, 10:37 PM | #8 |
Newbie Join Date: Dec 2005 Location: Salem
To bad he gave it to me for Christmas huh. Mwahahahahahah! (evil luagh) He says hes gonna make his own. we'll see.
01-22-2006, 12:59 PM | #9 |
Rock Crawler Join Date: Jan 2006 Location: woodpile aka HELL
nice!
02-07-2006, 05:33 PM | #10 |
Rock Stacker Join Date: Jan 2006 Location: A MILE HIGH :)
| sweet'
Nice.... i also like the sami, looks capable.
02-07-2006, 08:23 PM | #11 |
what is the white thing on your shafts? is it a extender
06-16-2006, 12:22 PM | #12 |
Been a while since I logged in here. The White Thing: yest I had to extend the driveshaft in the rear. amazingly enough it does not hang up at all. Jim: Yeah I heard you got into the rc scene again, that is great! I saw Tim and Eric the other day (saw them seperatly) at RCPLUS (www.rcplus.com) and they mentioned that you guys got into it to suppress the need for some real life crawling. Good to hear! Update: so I broke down and am building my own crawler now with the extra rc parts I have laying around. Parts list: Custom Aluminum tub chassis. TXT-1 Axles Revo Shafts Aluminum Threaded Savage Shocks. Maximizer Bead Locks. Tires? Hmmm not sure yet. ~Val |
06-23-2006, 05:23 PM | #13 |
Rock Crawler Join Date: Aug 2005 Location: White Lake
For your first it turn out very good.
07-01-2006, 11:17 PM | #14 | |
I know this thread is a bit old since it was started but I thought I'd toss in some needed info for those just now reading it.... To run Maxx or even better yet, Revo sliders on a X-Factor diff... Go pick up a couple of pinions for the AE BFT/MGT truck. They drop right in and are already pre-drilled and are the correct thing to do. It will cost you about $20-22 if I remember right. Saves time, effort and any headaches. Watch the ring and pinions on X-Factor or X-Factor2 diffs. They WILL slip and you will loose teeth. The axle housings tend to flex and cause issues with the R&P's. Do yourself a favor, learn to shim the diffs properly and shim them a bit tight, not too tight but just enough to have a bit of drag happening. Then go buy extra R&P's for the pig of an axle. You will need them. | |
07-02-2006, 12:39 PM | #15 |
Rock Stacker Join Date: May 2006 Location: Portland
| good info
Toyo, thanks for the good info. I am just now starting to build one of these things and that stuff will help out for sure. Looks like I will be visiting tammies this weekend. |
07-03-2006, 04:14 PM | #16 | |
Be sure to get with Ryan when you are there. He'll help you out with the XF junk, although I don't think Tammies stocks XTM parts. Ryan is our Crawler "in" at Tammies | |
03-16-2007, 07:53 PM | #17 |
The ole X has changed a little in the last year and a half. |
03-17-2007, 09:20 PM | #18 |
Pebble Pounder Join Date: Mar 2005 Location: Ulysses (In my hick town)
Nice rig. How well has the pede tranny lasted for you? I'm wanting to use it when I convert to electric, but I haven't seen many used in the X-factor. Also, the pics in the first post aren't working for me, do you have any pics of how the tranny is mounted?
05-30-2007, 09:09 PM | #19 |
I joined the Band! Join Date: Sep 2006 Location: ...
nice!
