Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > XTM Crawler
Thread: wider X factor
Old 03-25-2004, 05:44 PM   #1
Default wider X factor
Is there an easy way to widen the X's stance without getting funny offset wheel that sacrifice streering?
MoparManiac4x4 is offline   Reply With Quote
Old 03-26-2004, 09:47 AM   #2
Default Re: wider X factor
No. The only way to widen it, besides a different wheel, is by lengthening the steering knuckles, which you would not want to do either. I'm not too sure that it needs to be any wider than it already is. Can I ask, "why", would you want to widen it?
DirkDigler is offline   Reply With Quote
Old 03-26-2004, 03:40 PM   #3
i dont HAVE to widen it, maybe i'll just lower it a little bit. It not gonna eb an all out crawler, more of a hillclimbing, crawling, bashing. for the hill climbs and what not a wider stance cant hurt, but i dont wanna sacrifice my turning radius because it has to crawl good too
Old 03-27-2004, 07:20 PM   #4
im with dirk, the x already has the widest axle of any truck(almost too wide sometimes). but if you need tto make it wider, wheels with more offset are your best bet.
metallicamaxx is offline   Reply With Quote
