Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > XTM Crawler
Thread: Roll Cage
Old 10-25-2004, 12:48 AM   #1
Default Roll Cage
where do i get a role cage for my x factor? also what rims will fit my x factor without getting the savage shafts
Nathan is offline   Reply With Quote
Old 10-25-2004, 01:09 AM   #2
Default Re: Roll Cage
what should i do about the servo if i wanna drive my truck in the winter seeing how it is right on the axle? i was thinking of using a balloon and rap a rubber band around the end of it. what what else should i do to make it ready for the winter? this is my only basher so it will be drivin in the winter. never done winter driving before.
Old 10-25-2004, 10:10 AM   #3
HardBodyz makes the roll cage you want. Check at hobbypeople.net
Only Xfactor wheels will fit on the stock Xfactor stub shafts.
DirkDigler is offline   Reply With Quote
Old 10-25-2004, 10:19 AM   #4
thank you
Old 10-26-2004, 12:22 AM   #5
for the servo just pop open the case and apply some rtv silicone around the seam.then screw back togather.put a dab of grease around the output where the servo saver will go on.that will seal it there.
twisted is offline   Reply With Quote
Old 10-27-2004, 05:47 PM   #6
hey i have a brand new roll cage never fliped in perfect con. ill sell it to you for $50 if you would like. heres a pic with it on
MudXBogger is offline   Reply With Quote
