Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > XTM Crawler
Thread: X-Factor machined diff locker
Old 11-13-2004, 04:38 AM   #1
Default X-Factor machined diff locker
Hey everyone, do any of you guys out there know where I can find diff locks for the X-Factor. Do any of you know if the same design as the savage diff lock spool will work?
MorrisDaCat is offline   Reply With Quote
Old 11-13-2004, 12:54 PM   #2
Default Re: X-Factor machined diff locker
Are you just looking to lock your diff for good or something you can undo? cause JB-Weld works very well but you can't unlock them. if you want to be able to unlock them, go with "Silly Putty" or a "Neaded art eariser, and pack them in there good and it wont move untill you take them out!
Later
Jake
JakeDaSnake is offline   Reply With Quote
Old 11-13-2004, 12:58 PM   #3
Later
Jake
You can also get "Lock Snot" Which is great for making a Limited Slip as soft as you need it, or so firm it will be spooled. PM Toyofast here on the board for more information on it.
Otherwise, JB the spiders together, don't bother wastin money on a machined unit, you can do something just as functional on yer own ;)
SR5Dave is offline   Reply With Quote
Old 11-13-2004, 01:28 PM   #4
Nomercy's Avatar
if you really want to blow your hard earned green look for the guy who started making them under the name ferel cat racing. i saw him on the global hobby forum in the x factor section. i dont know if hes still around or making them any more.
Nomercy is offline   Reply With Quote
Old 11-14-2004, 12:06 PM   #5
I was searching www.hobbypeople.net and came across a diff.... not 100% sure if its locked or not (the crackhead at the store said it was) so im guessing its not locked... but hey its worth a crack (no pun intended) Its part number MV2275
http://www.hobbypeople.net/part/14564203.asp
PastryLikeDood is offline   Reply With Quote
Old 11-14-2004, 12:37 PM   #6
If you take the diff apart and flip one of the gears over on each side it will lock it and it is free.
Rockraider is offline   Reply With Quote
Old 11-15-2004, 01:03 PM   #7
If you only have the plastic gears, this may not last long. I believe that Feral Cat Racing is still around.
sam__kent is offline   Reply With Quote
Old 11-24-2004, 08:26 PM   #8
If you can wait until the new year, we are working on a locker for the X Factor. We had XTM send us out some parts.
Clayton
www.vertigoperformance.com
VertigoPerformance is offline   Reply With Quote
