Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > XTM Crawler
Thread: maxx sliders
Old 04-11-2004, 12:33 AM   #1
Default maxx sliders
how do you get them to work with the x-factors pinions?
dheavychevy is offline   Reply With Quote
Old 04-11-2004, 01:27 AM   #2
Default Re: maxx sliders
you drill out the pinions on the alxes. and the out put shafts on the tranny. you need to get a tmaxx brake disk and adapter so you have stopping power. you use a dremel on the out put shafts and gring out half of the bump stop and use drill bits on the axle sides NOTE:::: use a small drill bit and step up each drill size so you drill streight. you might have to cut the drive shafts unless you lengthen the wheel base. this is what im using on my twin engine x project that i have been working on for about 3 months . so it may work Good luck.
Rene is offline   Reply With Quote
Old 04-11-2004, 08:41 AM   #3
You can also use BFT or Savage pinion gears, they have the holes for the pins allready. The BFT pinion will go in with no mods but the Savage one you need to grind down a bit or it will rub on the diff.
Rockraider is offline   Reply With Quote
Old 04-13-2004, 10:08 AM   #4
whoa, a bft pinion matches up to the x-factor diff?
how about the diff itself? will a bft diff fit to x-factor axles?
badhoopty is online now   Reply With Quote
Old 04-13-2004, 10:10 AM   #5
Old 04-13-2004, 02:32 PM   #6
not sure what fits but do you guys know what drill bit size you need?
Old 04-13-2004, 04:56 PM   #7
i had my x-factor pinions turned down and machined to emaxx specs, but i think the stock x-factor pinion was 8mm.
Old 04-13-2004, 08:20 PM   #8
no what size do you need to drill the cross hole for the pin thanks for the help
Old 04-19-2004, 08:47 PM   #9
a bft pinion will not work. it is helical cut and will not work with the x-f non helical ring gear.
metallicamaxx is offline   Reply With Quote
Old 04-20-2004, 06:29 PM   #10
I drilled out the pinion with a diamond tipped drill bit. I also drilled out the yoke of the E-Maxx shaft so it fit over the pinion shaft.
jugg_crawler
jugg_crawler is offline   Reply With Quote
