Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > XTM Crawler
Thread: steering setup
Old 02-02-2004, 04:59 PM   #1
Default steering setup
what parts does it take to make the steering like a real truck with the servo upright and the short arm to the nuckle and the long one like a tierod ?
like on my 1:1 k5 with crossover steering
dheavychevy is offline   Reply With Quote
Old 02-03-2004, 01:34 PM   #2
Default Re: steering setup
You have to make your own braket to mount the servo somewhere on the axle.
You then just need some solid aluminum rod to make the links.
DirkDigler is offline   Reply With Quote
Old 02-03-2004, 05:53 PM   #3
solid rod ? how do you make it connect to the ends do you have to drill and tap it
Old 02-04-2004, 10:46 AM   #4
yes,
just drill and tap it. then thread in some threaded rod and put some rod ends on. that's it!
Old 02-04-2004, 04:45 PM   #5
sweet i can do that do you have any ends that you prefer
Old 02-05-2004, 02:14 PM   #6
XTM or Kyosho
Old 02-05-2004, 04:48 PM   #7
you rock dirk keep up the good work thanks again i am going to be doing this saturday
Old 02-09-2004, 10:49 PM   #8
does anyonw have pics of where they mounted their servos on the axles cause i mocked mine up and they hit the chassis or can you moun them on the chassis and run steering links to the wheels or will they bind durning the flexing
