![]() | #1 |
Pebble Pounder Join Date: Feb 2005 Location: HAWAII
is x factor axles better than txt axles? like r they stronger? y do some txt guys runs xfactor axles instead?
![]() | #2 |
Rock Crawler Join Date: Jan 2006 Location: woodpile aka HELL
i have x axils, and they seem really strong.......but what ever floats ur boat.....and they are like about a foot long
![]() | #3 |
probley......im still making mine, so......they are wide though
![]() | #4 |
wow thats wide, after looking at both i think its easierr to mount the sevo on the x axles..........
![]() | #5 |
ya.......their wide..........i havent compaired them to any other axil, besides a clod, and i dont know.......but i like them......you can easaly put a survo on the axil...
![]() | #6 |
Newbie Join Date: Jul 2005 Location: NewBoston
yeah im running them, theyre pretty solid, easier to put a servo on em, pretty friggen wide. i think they have a lower ratio than the txt ones too, not sure though. But i imagine if they were originally manufactured for a nitro truck they should be pretty tuff, mine work awesome.
![]() | #7 |
Rock Stacker Join Date: Jul 2005 Location: look to ur left
HANSOM all i have to say isTWINFORCE! |
![]() | #8 |
Quarry Creeper Join Date: Feb 2006 Location: Surrey B.C Canada
I run X-FACTOR axles on my tuber Total width is 16in from outside of wheel to wheel With narrowed kongs and stuff 1/5 scale servos with out a glitch And she finds lines that otheres can't follow but to each there own its up to you ![]() |
![]() | #9 |
owner, Holmes Hobbies LLC ![]() Join Date: Nov 2004 Location: Volt up! Gear down!
The x factor axles are almost too wide for a crawler IMO unless you run kongs. They would build up to a huge beast though. I like the force axles. They are easy to service and parts are interchangable with other vehicles, so replacements are easier to get. |
![]() | #10 |
Quarry Creeper Join Date: Nov 2004 Location: In the saddle...
I have mixed opinions about them as well. They are really wide as JRH mentioned, and I feel that the diff hangs a little too low. I haven't run mine in a while. They're a little too bulky by current standards, but they really are fairly bulletproof, provided you have a set with the 2nd gen. revised diff shims. The originals clicked a bit.
![]() | #11 |
TEAM MODERATOR ![]() Join Date: May 2004 Location: Tennessee
Twin/Mad axles are the way to go. X axles have a monstrous pig,if you like getting hung up and dragging your axles everywhere...they are the axles to use. X axles are 14" wide {hex to hex} The width is O.K. if you want to run Kongs. I wanted to width of X axles and the diff clearence of Twin axles so I made 14" wide Twin axles. Factory the Twin axles are 12" wide {hex to hex}. I've never run TXT axles but I've heard and read they are pretty stout axles. I believe they are a shade skinnier than Twin axles though. Coarse that should be expected. The TXT is a 1:10 scale and the Twin and X Factor are 1:8 scale |
