Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > XTM Crawler
Thread: X-Factor basic electric conversion almost done
Old 01-09-2005, 12:15 AM   #1
Default X-Factor basic electric conversion almost done
After getting an X and shortly thereafter realizing the futility of trying to crawl with a 30+ mph shafty, I put the truck on the shelf.
Now, a year later, I have ordered:
14.4 dewalt drill motor
5mm bore pinions *
Novak XR speed control
custom batteries from Maxamps *
Hitec 645 servo for rear steering
Airtronics VG6000 6 channel fm *
(* indicates ordered but not recieved yet)
My X-Factor already had carbon fiber 4-links, 8 shock setup (but it doesn't over-articulate, i.e. less than 90 deg. of articulation), and most of the aluminum hop-ups.
I wanted to retain the servo actuated brake (kind of like a line lock), and servo shifted reverse. About all that is left is to install the rx and batteries. I will also be lengthening the wheelbase as soon as I figure out a way to stretch the stock driveshaft (I want it to look stock)
No emaxx tranny, no GD600, just a drill motor and 16.8v (they say these motors don't mind being overvolted a little). In just a couple more days I'll get to see how it works
diesel72 is offline   Reply With Quote
Old 01-30-2005, 09:27 AM   #2
Post pic's when u get done! Are you into diesels too?
Eric
cummins driver is offline   Reply With Quote
