Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > XTM Crawler
Thread: new X-F linkage arrangment *pics*
Old 01-16-2005, 10:42 PM   #1
Default new X-F linkage arrangment *pics*
so i was fooling with my truck (still not sure if it was out of necessity or bordom) and i changed the lower links around. i get a little bit more articulation, the WB is slightly longer, and the truck is a tad bit lower to the ground. here's some pics:
Vitamin_J is offline   Reply With Quote
Old 01-17-2005, 03:52 AM   #2
Default Re: new X-F linkage arrangment *pics*
Those rod mounts are a weak point...if your going to keep them mounted like that, atleast get the aluminum upgrades. From extensive reading though, the next thing would be broken axle housings..just a heads up. Also in looking at your pictures, I noticed you have the screws for the center of the rear ends there upside down, they will bend or break off if left like that, when you encounter rocks, ect.
NITRO-DRAKEN is offline   Reply With Quote
Old 01-17-2005, 08:52 AM   #3
Your workbench looks like mine!!!!
Nitro is offline   Reply With Quote
Old 01-17-2005, 11:45 AM   #4
thanks Draken, i'll look into those things.
yeah, my workbench is a mess, someday i'll clean it........or i won't. haha, whatever
