BRUSHLESS CONVERSION KITS
Image shown is #5013. Car and electronics not included in kit. Individual images displaying the included items will be available in February 2008.
CLEAN UP AND GO BRUSHLESS
Plan an intervention with your 1/8-scale nitro vehicle, and admit it into electric rehab. Novak has the ideal program to convert your 1/8-scale nitro off-road vehicle into an efficient brushless electric machine by offering nine, inclusive Brushless Conversion Kits (#5010 - #5018). With some basic assembly, a 1/8-scale nitro car can be converted into a leaner, cleaner, less noisy brushless car with faster acceleration and speeds comparable to nitro. The Novak Brushless Conversion Kits were designed specifically for Novak’s 550-size brushless motors (#3424 HV 4.5 and #3426 HV 6.5) and include all of the necessary conversion components. So clean up, and reinvent your car as brushless!
WHY CONVERT YOUR NITRO TO BRUSHLESS?
1/8-scale buggies are built strong, handle well and are fun to race. With the increased popularity of brushless, R/C enthusiasts can experience a new way to drive and race while enjoying the many benefits of brushless.
Better Performance. Novak sensored-brushless motors provide extraordinary throttle response and controllability, and better acceleration and low-end feel. This translates to better control on bumpy courses and makes clearing jumps easier. Brushless motors also operate consistently in varying weather conditions, so you don’t have to be a tuning expert.
Lower Center of Gravity. Electric conversion provides a lower center of gravity for more agile and nimble handling.
Less Maintenance. Brushless systems are virtually maintenance-free. No engines to tune or rebuild and no spilled nitro fuel to clean up, so more time can be spent racing or bashing.
Cleaner Environment. Brushless motors are far cleaner to run than nitro-powered vehicles and are healthier for indoor racing.
Quieter. Brushless-powered cars are quieter than nitro-powered vehicles and will allow 1/8-scale buggies to run where noise restrictions are imposed.
Plug and Play. With a brushless-powered system, just turn on the switch and go. No engines to start, tune or warm up.
NINE CONVERSION KITS AVAILABLE
Nine conversion kits are available for many popular 1/8-scale off-road nitro vehicles:
Associated® RC8™ (#5010): To convert the Team Associated RC-8 Buggy
CEN® Matrix™ (#5011): To convert the CEN Matrix C-1 Buggy
Hot Bodies® Lightning™ (#5012): To convert the Hot Bodies Lightning2 Evo Pro Buggy
Kyosho® Inferno™ (#5013): To convert the Kyosho Inferno 777, 777 SP-1, SP-2 and SP-2WC Buggies
Mugen® MBX5™ (#5014): To convert the Mugen MBX5 and MBX5R Buggies
OFNA® 9.5TM/Ultra™ (#5015): To convert the OFNA 9.5 Series Buggies (ViolatorTM, RavengerTM and Jammin X1TM) and the OFNA Ultra Series Buggies (MBXTM, CompTM and LX1TM)
OFNA® Hyper 8™ (#5016): To convert the OFNA Hyper 8 and Hyper 8.5 Buggies
OFNA® Hyper 7™ (#5017): To convert the OFNA Hyper 7 Buggies
X-Ray® XB8™ (#5018): To convert the X-Ray XB8 TQ and XB8 EC Buggies
INCLUDED ITEMS
Novak Brushless Conversion Kits contain all of the necessary parts to completely convert a 1/8-scale nitro off-road vehicle into an energy-saving brushless buggy.
Motor heat sink and buggy-specific heat sink adaptor plate, specifically designed for Novak’s 550-size brushless motors (#3424 HV4.5, #3426 HV6.5 and original HV4400). Motor assembly installs directly to chassis with a four-bolt mounting system for stability, optimal heat sinking and lower center of gravity.
Two battery boxes and adjustable straps for holding an assortment of Li-Po or Ni-MH batteries
Motor cooling fan that bolts directly to motor heat sink
Antenna mount
Hardware kit
Complete instructions
Brushless vehicles are a popular segment in the racing industry, so don’t get left behind in the nitrofumes, and join the brushless revolution!
1/8-BRUSHLESS CONVERSION KIT COMPATIBILITY
To mesh with its Brushless Motor Conversion Kits, Novak is offering Mod 1 Pinion Gears. These heavy-duty gears are recommended when converting 1/8-scale Nitro off-road vehicles for brushless electric use and fit seamlessly with Mod 1 spur gears commonly found on 1/8-scale Nitro vehicles. Designed to maximize concentricity, these hardened gears can be used in any application and with any motor that has a 5mm output shaft, including Novak’s HV High-Voltage Brushless Motors that have been updated with the HV Brushless Motor 5mm Upgrade Kit (#5924).
http://www.teamnovak.com/products/brushless/conversion_kits/index.html
