nd4spdbh
OK i was sort of pissed when i found out that my Lrp runner (ITS A POS) only put out 4.8 volts soo i started thinking. I looked around at Mpi voltage regs. and was not impressed with the price. Then yesterday i was looking around at radioshack and i found a 5 volt 'fixed voltage' regulator. and i was screaming in my head VOLTAGE REGULATORS ARE NOT FIXED YOU CAN CHANGE VOLTAGES. N e ways i got home and i was like DOH i could use that to make a 6 volt regulator for my hitec 645mg.
OK now on the HOW TO.
[Size=+2]Intro:[/size]
OK i will be explaing how to build a 6 volt regulator. it actually will come out to be about 5.83 + - .07 volts. One little unit will have a current of 1 amp. this may not seem much but you can line 2 or 3 or as many as you want in a parallel format to get the more amperage. ( this will be explained later). One unit will cost 5.36 without tax! alot cheaper than 30 bucks for a Mpi reg pluss you will have parts left over to make more!
NOTE: i would recomend a heatsink ( even if its just a little piece of metal ) if you are going to encase your regulator in something like i did:
[Size=+2]Materials:[/size]
+5V Fixed-Voltage Regulator 7805
22 ohm 1/2W 5% Carbon Film Resistor pk/5
150 ohm 1/2W 5% Carbon Film Resistor pk/5
Dual Mini Board
Also you will need some wire and connectors for you servo wires unless you are willing to solder them right on. And of course you will need a soldering iron, solder, pliers... the necessary tools for electronics working.
[size=+2]Procedure:[/size]
OK now that you have got the materials its on to building.
Ok you need to kno what the legs on the regulator do. so if you set the regulator Flat side down from left to right it goes: IN Ground OUT
So like this:
Now wire it up like this:
MAKE SURE YOU GET ALL CONNECTIONS RIGHT!!. Then test it with voltage meter just to make sure its at or under 6 volts.
NOTE: if you plug it into you battery and it gets excessivly hot UN PLUG IT !!!
[size=+2]Now for thoes ppl who want to kno how to wire in parallel[/size]
Do this.
... Upping the voltage on ur servos works wonders... JUST DONT OVER VOLT THEM!!!! NOTHING OVER 6 volts PERIOD!... He he my hitec 645mg acts like its on sterioid compared to 4.8 volts. I hope this helps ever one... if you have n e questions reply to this post!
Here is my voltage regulator: It doesnt get all that hot after runnin for an hour it just get a little luke warm!
Dual Mini Board
So like this:
Do this.
