team3six
www.team3sixrc.com
Honestly, people thought that the earth was flat and that only birds could fly. Anyone want to place bets?
The .037 you are not seeing because air resistance has been negated due to the RPM's being below 30 rpm. With a tread depth smaller than .3" I don't see the resistance meeting the minimum K value to really be warranted in the aero formula.
All this jibber jabber is making me nervous... Harley, are you working on a nuclear powered crawler?! :shock: :shock: :shock:
Wonder what DK thinks about this new idea? :lol:
Ok. Tire selection not withstanding, certainly you have a chance at being correct if you are measuring the RMP cumulatively for the dual motor approach. 30 RPM individaully would cause an excess when processed through both axes simultaneously as your 3D image suggests you might. In that case, condensation is going to become a matter requiring still further exploration and a likely thermal solution to the problem you're having with the Rock Force's performance.
I trust you're planning to filter the results of your math through a binary version of Berwalt's Opposing Rotational Mass Formula before you begin initial testing.....??? Safety first.....
Sooo do dual ring and pinions counter rotate to eliminate torque twist ?
Is this more competitive then a MOA ?
That will never work.
Unless your mounting the transmission to the case as well...
Or you run 100t's...
So let me get this right so I understand as I it as I think I do. If I am wrong then the boat left along time ago without me and Im sorry for being ignorant. I think I understand the theory. By the way (all the mathmatical talk is only confussing the basic guys! even me since I am a land surveyor by trade.) So this is what I am figuring it to be if I am correct. Basically the wheel has a triangled beadlocked rim and the tire would have to be specially designed to seat on the beadlock. But the outside of the wheel in all essence is still rounded. So when you are moving along rocks or bumpy ground, the flat parts allows you to be stable while the edges give you the advantage of sticking to a specific area either up or down with lower chances of movement? The wheels are still round on the outside but because the foam inside allows for seating to whatever your running the wheels on. It has the capability to grip on more substances and even more so because of the knobs on the tire surface? is this what I am understanding?
To add, because this would be on 4 wheels, and the speed that these go, the chances of all four wheels making seat at the exact same point is vitually slim to none. even so, the tires round surface would overcome the torque needed to move in forward or backward motion. Still higher torque, but not enough to cause extreme or higher than needed force.
Well Josh, I got the proto set all programmed up. "thumbsup" Waiting on after hour machine time now.
