Crawler Ted
I would suggest running both batteries in parallel to one plug, that way both your ESC's always see the same voltage and will give the most consistent performance. You can just run one batt to each, two BEC is safest if you are running high end servos.
I know Austin (Gatekeeper) has to run 2 BEC's on his since he is running two 300+ oz servos.
Just trying to wrap my head around this .
Run both batts in parralell because the servos would draw power from one not both ? is that what you mean ?
A buddy had a suggestion as well ,What about running a third batt just for the servos through the ccbec ?
Or could I run one ccbec from each batt to each servo ?
I too am running 300+ oz servos .
