Vanquish Products - ALRC Turkey Crawl - Nov.14
Ok AL guys, if we dont get more judges to step up and help, I am going to start pulling names off the list. :flipoff:
I have done this long enough with little help but from a few people. Its time for some of you other guys to step up.
HELLO
Ok i told you i wil help out on 2.2 and scale what else you want.:evil:
Must have missed that post. :mrgreen:
Got you down......so that means that you can run. :-P
Looks like I am going to have to load the random number generator to see which al guys get cut..........
I will build help with course design:evil: maybe you finish maybe you dont method"thumbsup"
Ahhh hell shomebody hide the ballz:shock:
Seriously If you want to make it hard do it "WORLDS STYLE" with multi-gate Bonus lines!
That way normal drivers can finish, but the better drivers can still be "TESTED" "thumbsup"
Is this all we need for the scale sheets?
If someone could, please print one out and see if any changes need to be made.
how about this for now. i can put it in spreed sheet form..
Scale Class - Modeled after typical street legal off road vehicles
Chassis must be OEM stock or custom ladder style that must extend over the axles. OEM suspension may be modified in any way. Construction material is not restricted.
Tires are restricted to a height and width only. Tires shall not exceed 4.75" in height and 1.75" in width. 1.9" or 2.2" wheels are allowed. No restrictions on tire manufacturer.
Must run a complete body....bumpers, fenders, doors and tailgates must be intact. some fender trimming is allowed but must retain the basic shape. A shortened or lengthened body is allowed. A tube bed must have a functional bed area capable of carrying a full size spare. (rear fenders and tailgate rules do not apply to tube beds)
No 4 wheel steering allowed
No "dig" or rear axle disconnect allowed. Dig transmissions used to disconnect the front axle only for selectable 2/4wd will be allowed. No rear wheel only penalty will be given for use while on a course.
Wheelbase and width is only limited by your body, but it must fit within the bodys fender wells'
Battery must be placed within or on the chassis.
Scale Bonus System:(Max -40 Points)
Chassis Steering and Suspension (Max 20 points)
• Ladder frame: Chassis must be no less than 12", and must loosely resemble a 1:1 frame rail. (-5 Points)
• Leaf sprung suspension: leaf springs that are able to support vehicle weight.(-5 Points per axle)
• Coil sprung suspension. Coils and shocks must be separate. (-5 Points per axle)
• Frame mounted steering servo: Servo must not be mounted to the axle. Bell cranks or tie-rods may be used, but the servo shall not be mounted to the axle. (-5 Points)
Exterior & Interior Scale -5 Points each (Max 15 points)
• Working Lights: (-5 Points)
• Scale Bumpers: Bumpers placed on both the front and rear that are to scale. Bumpers must be mounted to the frame and must not be a molded section of the body. (-5 Points)
• Scale Interior: Must have at least three items:
Steering wheel, Seats, Console, Driver, or Dash w/gauges (-5 Points)
• Scale Engine compartment: Engine must be scale sized, and over 1" tall in height." (-5 Points)
• Full function Spare Tire (-5 Points)
• Hard Bodies, ExoSkeleton or Roll-cages (-5 Points)
Misc Scale Items -1 Point each(Maximum of 5 points)
• A maximum of 2 of these items maybe mounted the rest must be placed in a tool box or roof/cargo rack:Axes, shovels, Hi-Lift Jacks, bed rolls, tarps, ropes, tow-straps or any other items that's intended use is not part of the vehicles operation.
• Cooler must be mounted with additional points for ice and Beverages for cooler
• Scale CB or 'whip' antenna
• Trailer Hitch mounted to bumper
• Winch: Fair leads or spool assembly mounted to bumper
Scale Point System
All rigs in the scale class will start off with 0 points and points will be deducted during the competition. The object is to complete the course without incurring points. There is no maximum point limit. One free reverse will be allowed per gate. Point deductions are listed below.
Reverse +1
Gate +5
Reposition +10
DNF +40
Rollover +5
Touch +5
Rescue -5 or +5
Reverse: Using the throttle to reverse course. Non powered roll backs are allowed. Each driver is allowed one reverse per gate without penalty.
Rollover: Points will be assessed when a vehicle rolls over and does not right itself or cannot be righted without touching. Winching is allowed without incurring a penalty. Once righted a vehicle must be driven back into position. All gates are still live while on a gated course.
Gate: Failure to pass all 4 wheels through a gate or touching a gate with any part of the vehicle. Winching through a gate is allowed.
Touch: Any physical contact with the vehicle while on a course. If a repair must be made then the vehicle maybe touched, however the vehicle must be placed back into position it was in prior to repair. No touch penalty will be incurred when setting up a winch or tow straps as long as the vehicle is not repositioned or moved.
Reposition: Penalty is incurred when the vehicle must be physically moved. This includes picking up the vehicle or a rescue by another vehicle.
Rescue: Using another vehicle to free a vehicle on course. The rescuer will receive the bonus points while the rescued will incur a rescue penalty.
Time: there will be no time limit, but lets keep it reasonable.
DNF: A vehicle is unable to complete the course regardless of a reason a DNF will be assessed. If a DNF is assessed then they will be scored with +40 points added to their current point total plus 5 points for every gate not completed.
I would judge but I have only been to one comp going to my second this weekend.
I appreciate the offer Creepy. "thumbsup" With the comp being as big as it is, I would rather have some guys/gals with a little experience just so there is no arguing about scores and what not.
We have plenty of guys that know how to score, just going to have to start pulling names I guess.
