Punks Lightweight Cdw Bully
punkuup5150
lodi
build starting tonight :D just getting you ready for it "thumbsup"
edit- might as well show yeah what im working with
Bully V3 Lightweight axles
Xirtic steering
CDW Chump chassis
CDW Chump Stix
punk dig switch
Vanquish Dh pro comps up front
Vanquish Slw v1 .7 out back
Vanquish v2-3 .7 black/blue ordering next week
Rovers w/ Nova foams
fxr
cc bec
losi crawler shocks
proline crowd pleaser crawler body
revo rod ends
jr 8711
jr metal servo horn
integy 35 turn motors
3s lipo
dx3 3 postion switch mod
just got home rebuilt the rear axle but had a problem >_< i killed a bearing so now i have to find out what size it is and order one >_< pics will come tonight i have to go to a xmas party but when i get home imma finish the other axle and get everything bolted up i wish i could test it grrr
Bully porn
and on with the bully porn- so far i have only rebuilt the rear. i detonated a bearing in the rear tube and going to have to wait for a new bearing. so i figure ill wait to do the fronts since im ordeing a new bearing kit and will save me some hassles and hopefully no more breaking of bearing on my part. so heres a few pics
Rocking the Rc4wd bling-
mmm parts
cdw before swapping of parts
Much needed upgrade "thumbsup"
Bearing destruction!
hopefully i can get the bearing kit in soon so i can get this finished up and out on the rocks :D
right now im useing stock pinions. i run a thicker gage wire in the rear to counter the clodstall. ive thought about gearing down one but with me running 35turns and 3s i have way more power then i need allready
You say you run a bigger gauge wire to the rear motor than you do the front and that gives you less clod stall.
its basic electricity flow, pretty much path of lease resistance is where the powers going to go, this has gotten rid of 99% of all clod stall i had previous and i like the 1% it still has lol. i think im running 16gage to the front and 12 to the rear. i havent finished with the front axle yet im going to tear into it now and also work on my steering look for pics soon :D
ok just got done rebuilding the front end. came acrost a problem. i have the beefed up knuckles and tubes. unfortunatly the brass bushing that goes in the knuckles is to short. im going to send racer an email about this as it seems i may not be the only one to have this problem and hopefully they can get it worked out. next is steering :D
all done and built up holy crap these things are so much lighter :D
and the problem i found >_< hopefully rc4wd has a solution-
and not sure if anyones seen the awsome kit xirtic has for steering so i took a pic of it. looks so great with the black bullys i wonder if he had insider knowledge about the color of the axles before produceing these
the Build looks very cool. "thumbsup" How much weight did you cut? and what are you weighing now?
Thanks, as I too am trying to build a lightweight Bully and trying to compare the weight.
i got to get this steering figured out first lol. running into a snag need to play with how it all sits for a bit and see what i come up with. and there wont be a vid for a while i need a new bearing before i can do ne thing >_< and as for weight loss i have no idea as of yet the axles not on the truck yet. im guessing ill be sitting at right around 6.5 pounds-7 im running alum links and solid steel top links and need to go to a lightweight wheel
my steering problem >_< im going to try and mount the servo on top this time. and also play with the spacer placement and get rid of the bend ive come acrost.
