mrpink
face book cant tell the difference between a 200 lens and a 2000 lens....![]()
This should work out just fine for you then.....
post up some of your results.
p!nK
well after all the suggestions im kind of looking at 30D and the Xti. leaning towards teh Xti for price. havent looked at any nikons.
one thing i cant find is on te Xti. can i set it to full auto so it takes care of everything. but still set the focus like i want. ie set the focus with the seperate focus button ahead of time. then just mash the shutter button whenever i want to take a pic. with breaks in between etc. since my focal length will always remain the same. so a newb can grab it and just button mash teh shutter and capture fast pics of action. no focusing required? all in full auto. or is this a fuction of the manual setting only?
killer info. you sound like your doing exactly what i want.
right down to the blury backgrounds with crisp action.
this is what im after (me in the pic)
http://sphotos.ak.fbcdn.net/hphotos...522757915_100001285040367_41998_6233481_n.jpg
ive found a Xti with a 200mm lens for cheap. i may bite on it.
any more info you can give on the hold with thumb method, and single press focus method would be greatly appreciated. (i wonder if the xti has the hold thumb/focus feature)
and also how to set up camera in the AV mode. what about ISO and all that other stuff i dont understand.
some how to's would be great!
To get an image like to one you posted, you will need to be shooting at a minimum of f/4 (to get that shallow depth of focus), and a shutter speed of 1/500 or faster (to freeze the water and other motion). ISO would most likely be set to 200 in a situation like out on a lake. If I had to guess on that photographers settings I would say 1/1000th, f/2.8, ISO 200. There is the chance that the effect was created in photoshop.
Post up a link to the package you are looking at.... The words cheap and sharp usually do not go together when talking about lenses (save for the 50mm 1.8 or nifty fifty as cannon goofballs call it)
L glass is $$$$$, but very nice.
p!nK
my current point and shoot is 12X optical. i would say for the wake boarding shots we use somewhere around 10x. what mm zoom lens would i need to acheive that magnification?
My guess is that the pic was taken between F2.8 and F4. In my other pics that were taken at F4.4 you notice the background is not blurred. That is because of the wide viewing angle. If the guy who took your pic has a 200mm lens he might have gotten the background blur at F4 because he is zoomed in tight on you.killer info. you sound like your doing exactly what i want.
griz: thanks for the photos of the tubers but those settings arent what im after. they look just like my $400 point and shoot.but the info about the lens 70mm zoom is invaluable. i definalty woiuld like more zoom than that.
griz: thats more like it! that looks more like a $2-4k setup should imo! great info on the ap and iso! man that REEEALLY helps this newb.ive heard lots of people mention that apeture priority, and that alot of people like that mode. thanks! yeah like anything you have to practice to get good. awesome soccer shot btw
Donzi: ill get the model for you. and ill check the lens. thats a great idea. i didnt think of that. i dont think it give you a read out of what magnification your at like some of them do. there would be no way to take a pic at 9x, 10x, 11x etc. yeah ive heard lots of people say the Xti is too small. pinky has to wrap underneith the body. but that a battery grip fixes that. (hey im learning the terms!)
The self cleaning option and higher resolution is about all the XTi has going for it on the 30D. Others will certainly disagree, saying that its better on little more than the fact that it is newer. If you compare the statistics of the two, you will see that the 30D is superior most capacities. As for the 30D compared to the XTi, it has a higher max shutter speed, faster frame rate, 1/3 stop ISO settings, larger buffer, faster flash sync, spot metering, longer battery life, better build, ISO 3200, and a few more minor features. You decide if thats worth an extra $300. To some, it is not, to others, it makes all the difference.
To continue with what Leopold started... The 30d has a dedicated status LCD, dedicated rear dial, larger and brighter viewfinder, better grip, better interface for most functions, and a few more minor features. It is lacking a relatively ineffective dust removal system, and an extra 2 megapixels.
The XTi is by no means a bad camera- you really need to hold and shoot with each camera to make your decision.
I owned a Rebel XT and have used an XTi, but you couldn't pry my 30d out of my hands.
XTI is just a plastic consumer grade camera that does not even have a glass pentaprism.
For the intended family / amateur use it is a fine camera.
the Rebel is intended for amateurs. That doesn't make it a bad camera at all, just one that many pros wouldn't be as interested in. The 30D, while certainly not on the level of the 1 series bodies, is more professional. It's studier built so it can be banged around a bit more, the mirror mechanism is designed to be fired a lot more, the controls allow for a lot more control to be done a lot more easily. The Rebel is intended more for Aunt Sally to get pictures of the kiddies during the family vacation to Disney World.
Once you press the shutter button, it doesn't make that much difference which camera body you get, they will both produce excellent images.
Before you press the shutter button is another matter. As others have mentioned, I much prefer the ergonomics of the 10D/20D/30D line. Having two dials/wheels (one on the back and the other by the shutter release) to control aperture and shutter speed (manual mode), and exposure compensation (aperture and shutter priority modes) is faster and more intuitive. In some situations, it can make the difference between getting and missing the shot.
If the price was the same, I would pick the 30D any day. Even with the price difference, I would still pick the 30D (or a used 20D).
