SteerAndStuff
Are the cutting brakes a worthwhile feature or more gimmick on these? Trying to decide if its worth the switch for the cutting brakes. Didn't seem to find any thread on the topic.
It a brake that will give you the ability to lock up right or left rear wheel and have 3 wheels still powered. I'll try to find the video.What is this, I've not heard about it yet?
Well with soo much front weight bias I cannot see where the light end of the rig with the lightest wheel/tire is going to allow you to piviot like cutting brakes on a 1:1 IMO. The big benefit I see is making an uphill turn or turning out of a hole?? If you watch the vid it would appear to me that dig will still bring about a tighter turn??
They are not released yet, but should be very worth while. Ability to turn a lot tighter then a dig would allow.
That is what I thought.Not true! I have tested it multiple times in a past rig of mine. The rigs do not have enough weight/rear traction to hold the back of the rig with only the inside rear tire locked. You need both rear wheels locked to have the tightest turning radius.
The cutting brake will help more in situations of climbing ledges off camber and getting out of holes"thumbsup".
Three wheels powering out your turn is tighter than two... It all depends on your set up. If you dont have the correct weight set up to use CB and/or enough traction on how your rig is positioned, then yes your statment is true. I understand where your comming from though.
It's obv that you would get more turning radius. Try a mock up test:
- Place your rig on the floor.
- Hold either your left/rear or right/rear tire in place. (1 tire)
- imagine 3x tires taking you through the turn.... super sharp, tighter than a conv dig set up.
* The thing is, using it in the right situation....AND having a t/x set up that can perform these duties. If your using cutting brakes, you better already know all your features of your rig and know how to drive the thing in a comp enviorment. "thumbsup"
no disrespect wrightcs77, I know you know you shit. "thumbsup"
I have a feeling the best way to use the cutting brake will be to also dial out a bit of rear esc.
