Absolutely lost on why Im blowing BECs so heres the run down.
Losi CC - Tekin RS w/17.5 - Futaba Fasst - Hitec 7950 - Hitec 225 dig - 3S 20C Lipo.
I was wiring the bec to the battery plug then running it at 6V plugged into the receiver with ESC red wire pulled out. When I roof the truck and pull on the throttle the system dies out. I can see the esc lights blinking and the rx light go red, wait a second and system rearms and can run again.
Also if I put any type of load on the truck the same exact thing happens. Even holding the truck up in the air and pulling the throttle reverse to full will make the esc light drop to red and I lose the bind it seems.
I tried using the bec through the ESC and its only worse, Ill actually lose power to the motor before it dies out.
So I found wiring the bec directly to the servo helped stop it and ran that way for an entire outdoor season. In November I blew my JR9100Z and bec, thats when I got the 7950 and wired a new bec in the same exact way.
A few weeks later I noticed the servo acting weird, like sticking turned then it just up and stopped working. I noticed the green light on the bec wasnt on so i plugged the servo directly into the receiver and it worked.
So I wired in another bec and everything worked again, for atleast a few more weeks. So far I have gone through 4 counting the original with the 9100Z servo.
So I called Castle on monday for some ideas and help. After talking with them about how the bec was wired I had thought I knew the problem. I was connecting the red & black of the servo lead to the red and black of the bec output. Castle said I needed to leave the black wire from both going into the rx, they both needed to be grounded and the rx would do this.
So bec #5 went in the rig and wired up with only the red wires from the servo and the bec connected together.
Went to go practice last night and blew another one. BEC set @ 7.0 ... wired the was Castle told me and same exact thing happened again. Now Im frigin lost ....
I also noticed one other thing last night when using the esc bec. When I wiggle the steering back and forth quickly the servo after a few seconds seems to slow down, you can hear it too, the rx light flickers and if i try to pull the throttle I have like no power to the motor. Once I stop steering and wait a second its like everything is fine until I try to steer some more.
Servo doesnt get hot, not even warm. I have the cap on the ESC, I actually have a bigger 25v cap instead of the 16v Tekin gives ya.
I thought maybe I was pulling past the 20c my packs were rated for so I tried a 25c and a 40c pack. Same results with each pack. I thought maybe I had bad rx's so I tried 2 others and again same results. Then I tried a different servo, hoping but not hoping that was the problem, but again even a simple Hitec 645 seems to draw the power.
Im at a loss ........... anyone ever have something similar? Could a servo, good or bad, cause such a big load on any part of the radio system?
I simply dont know what could be causing the bec's to blow after little use ......
Thoughts .... Ideas ....
