crawling-wallz
here is a new way that i found that you could get more flex out of your honcho or scx10. Great thing is you spend 0 dollars "thumbsup". First thing you wanna do is take your front shocks off, and remove the springs. Remount them, then lower the shocks by mounting them lower on the post that you mount the body posts See pics for reference). Add some weight like a wheel in the back to help get that flex in the front. keep the rear completely stock with stock springs, because the back will do its job the way its suppost to. I found this helped me out alot because with more flex i could get through more tight spots without flipping over. Good thing is that by re positioning the front shocks, when the truck sits it sits at exactly the stock ride height and it doesnt sit more higher in the front or more lower. Now on to the pictures
Some closer flex on the left side
Now onto some major flex here, before this i would always flip here, but now i cant
here is how the front shocks are mounted.
Here is the back, like i said completely stock in the back
PLEASE LET ME KNOW if you guys got a chance to test this out on the rocks. Some feed back would also be great
