EEM-CrawlinMachine
These units are badass, also compatible with the RC4WD XR4 for those who use that tx"thumbsup"
Got mine in the mall yesterday, thanks for the quick shipping. I do have one question with respect to the connecting to the unit (mine connectors where not labeled). I could go with the trial and error method but I thought I would as first. So are the connections as they are soldered from the end of the board going in (starting with the one closest to the end of the board) like this?
First – Front ESC
Second – Channel 2 (Throttle)
Third – Channel 3 (Proportional Control)
Fourth – Rear ESC
Thanks for picking up the production of this great product.
Ok i forgot to tell everyone who has ordered, i don't have labels, so all the servo plugs have a marking in them with a engraver tip, a F,3,2,R
F=front esc; 3=ch3; 2=ch2; R=Rear esc.
Sorry if this cause any confusion.
hello losikid !
i send you paypal !!
i wait your news ! thanks !
so i can get those pre-orders out by Monday...
what would be a good amount for you?
yes that should work.
In simple terms your channel goes from -100% to 0% to 100%, when at 0% you have even mixing, when at +/- 100% your at full dig. Everything in between is a bias mix. So your 3 pos will act as dig, then when swapped over to lin you can get bias control, although not real useful unless it can hold a position somewhere in the -100% to 100% range
