Bay City or Tri Citys MI
well thats awsome now i have to think what i want to run for a motor and speed control now!:twisted: i fryed my motor!:evil:
The key to this chassis is the frog legs!!! Not the ones ya eat! JAY. The lower links.
I am intending to promote this as a sportsman chassis, but it will work for pro as well...a dig will fit with proper transmission placement.
This chassis is intended to be used with 3.5" shocks up front, and 4" shocks out back. If you choose to use different lengths than this, I cannot guarantee performance.
This is one BADASS kit! It comes with the following:
2 upper Delrin topper chassis pieces
2 aluminum anodized chassis sides (blue, red, grey, or purple)
1 Delrin skid plate (68mm total width including the aluminum protection sides)
7 Delrin cross bars for the topper (all M3 threaded)
2 Delrin suspension cross bars (M3 threaded)
4 Delrin spacers between the topper and chassis plates
Front and rear lower links (Frog Legs)
NOTE: The frog legs are drilled and tapped for M4 and set screws 4mm x20mm are included. You must source Traxxas Revo ends. If you need part numbers or assistance, just ask.
Also included:
All stainless steel hardware.
14 M3x10mm button head screws for the cross bars
12 M3x16mm button head screws for shocks, upper links, and connection points between topper and chassis plates
4 M3x30mm button head screws for lower links
8 M3x5mm button head screws for side panel mounting (The chassis is threaded M3 in 5 places for super simple side panel mounting)
12 nylocks
And, of course...stickers and a business card. You get it all for the low price of $85 USD shipped to your door...anywhere in the world.
This chassis will bolt in to your AX10. It will work with your stock or aftermarket skidplate, as long as it is the standard dimensions.
The material is Delrin, and the cross bars are Delrin as well. Includes 7 cross bars and 14 mounting screws for the cross bars.
this is the frogger chassis jay has!:lmao:
Jay has the Og frogger and hook still has the the dart which is still a frogger chassis. the whole frog thing comes from the lower links which looks like frog legs. If ya look at his chassis the poison dart is called the Frogger v2.1 "poison Dart"
Are You JoNeS'N Yet?
Frogger V2.1 "The Poison Dart" chassis for AX10
I wont be running sunday, I have my daughter.
On the positive side my body came in. I picked up some red paint to make the rust color inside and black for the trim. Going to hit the trim parts with some black before I paint the whole thing. Nick I'll have to hook up with ya sometime next week to start figuring out all the cutting and mounting.
It does look like the dingo cage will fit nicely inside the cherokee.
Jay, I'll bring the slash over if your guy is still interested. I do think that I'm going to keep the vxl to use in the Wraith I plan on buying in the spring.
lol that's the hobby! besides the the straight axles and the universals are easy get the measurements and make a flat spot but the part im still trying to figure out is how he attached the axle housings on re attaching them after there cut!
