lordjasper1988
ive been looking for ages for a complete list of tires and wheels and couldnt find one...so i im doing one here... and now!
in this thread you will see all aftermarket tires and wheels that fit the losi micro rock crawler (McRC) that i can think of lol.
you will see a pic of said item, dimensions, rating, where to get it, you get the jist of it.
also if there is info missing in this thread eg. dimension, url, even another item, let me know with said information and ill put it in this thread.if you are rating said item *-*****, * being very bad and ***** being exceptionally brilliant.
i really hope this makes a sticky so people get to the info they need with ease.
so without further adue lets start with wheels/rims whatever you wanna call them
WHEELS:
gearhead
Gear Head RC 8Trax Micro Crawler Wheels
weight:???
hex: yes
rating:???
comments: comes in aluminiun, white delrin or black delrin.
url:Micro Crawler Wheels & Tires
HR
hr beadlocks
weight:???
hex: yes
rating:****
comments:good wheel, needs a #1 phillips for screws, rings come in red, blue, black.
url:Losi MICRO-ROCK-CRAWLER parts at the thetoyz.com - All your Losi MICRO-ROCK-CRAWLER parts in one superstore!
RC4WD
rc4wd micro beadlocks
weight: ???
hex: yes
rating: ****
comments: good all round wheel.
url:Losi Micro crawler Beadlock Wheel
BWD
micro vertex beadlocks
weight:???
hex: no, pin drive
rating:*****
comments: only BWD wideners work with these wheels. can use spent bullet casings (.17 hmr) to add weight and a little bling.
url:Micro Vertex's Silver
TIRES:
RC4WD
crusher x/t
O/D:48.3mm/1.90inch
width:18mm/0.70inch
rating:***
comments: good scale tire, not the best grip but not bad.
url:Rock Crusher Micro Crawler Tires
Rok Lox Micro Comp Tires
O/D:1.90"(48.3mm)
width:0.70"(18mm)
rating:****
comments: very good comp tire, plenty of grip, does very well on all surfaces.
url:Rok Lox Micro Comp Tires
Mickey Thompson Baja Claw TTC Micro Crawler Tires
O/D:2" (51mm)
width:0.78" (20mm)
rating:***
coments: looks like there moving when they`re not!
url:Mickey Thompson Baja Claw TTC Micro Crawler Tires (pair)
Interco Super Swamper TSL/Bogger Micro Crawler Tires
O/D:1.98" (50.5mm)
width:0.78" (20mm)
rating:****
comments: micro version of the original, designed for that sticky situation!
url:Interco Super Swamper TSL/Bogger Micro Crawler Tires
RCTRAX
miniqlo miclows
O/D:approx 2.3"(60mm)
width: approx 0.94" (24mm)
rating:****
comments: big angry tires that will take anything.
url:RCTRAX Miclow Tire (2 pcs) : [MQ-MC01] : MiniQLO
wideners
stock width 3.38"(86mm)
crawlerx.net
extention:+0.39"(10mm)
material:delrin
rating:**
comments
verall 10mm extention over stock width, some cutomers experienced stripping or excesive wear and tear. ok product.
url:MICRO Wheel Widener Kit [MWW001] - $9.97 : Crawler X, Rock Crawler Parts
BWD
extention:???
material:aluminium
rating:???
comments: barrel nuts not inclded. only works with bwd wheels.
url:Micro Widener Hubs Only
LOSI
extention:+0.23(6mm)
material:alu/plastic
rating:****
comments: good cheap mod, overall 6mm extention over stock, easy mod.
url:Losi LOSB1737 - Micro 4x4 Stub Axles & Wheel Hexes
thats all i have for the time being guys, thanks for looking and remember if you have info you think needs to be in here let me know and ill put it in if its missing
also i recommend if you want a motor upgrade get a getbent 80t predator motor and a 90t if your going to use or already use miclows.
thanks again guys.
happy crawling.
WHEELS:
gearhead
weight:???
hex: yes
rating:???
HR
hr beadlocks
weight:???
hex: yes
rating:****
RC4WD
weight: ???
hex: yes
rating: ****
BWD
weight:???
hex: no, pin drive
rating:*****
TIRES:
RC4WD
crusher x/t
O/D:48.3mm/1.90inch
width:18mm/0.70inch
rating:***
O/D:1.90"(48.3mm)
width:0.70"(18mm)
rating:****
O/D:2" (51mm)
width:0.78" (20mm)
rating:***
O/D:1.98" (50.5mm)
width:0.78" (20mm)
rating:****
RCTRAX
miniqlo miclows
rating:****
wideners
crawlerx.net
material:delrin
rating:**
comments
BWD
extention:???
material:aluminium
rating:???
LOSI
rating:****
thanks again guys.
happy crawling.
