yoda@4x4
Looking for new Trails
wow broke already.... hope to see some video soon...
Thanks Colby!
Well a quick update...I got everything dialed in. New wheels and tires....THEN BAM! My husband ran into the passenger wheel/tire going about 30+mph in his Slash (Exo was at a stand still). Sad to say that it bent the hell out of the recalled button head screw that the control arm rides on. Looking for the post recall parts is going to be loads of fun. I think for the time being, I will convert the front back to the pre-recall setup. The collision also tore the side panels out from the screws and tore both front shocks.
Ugh I'm so sad!!!![]()
Yep, slash is perfectly fine. :roll:and of course, the slash was fine, right.:roll: i would be mad, not sad. pics of the carnage please.![]()
I think mine is :xDang! Gotta wonder if the EXO is jinxed.
that easily? it took a direct hit to the tire from a slash. and from the sound of things it seems the slash hit at its strongest point. that was no light breakage. anything would have been taken out like that.I really liked these when I first saw them, but now I'm starting to wonder if they are worth the money if they break that easy :shock:
Mine hasn't broke yet (probably just jinxed it) and I drive like ass hahaha
Never tried it on 3s.I've seen that you been using 2s instead of 3s. What have you been seeing temps at with 3s? Or 2s.
I will post some pics tomorrow.Could you post pics of how you installed the Big Bores? I assume that you changed all 4 to big bores.
Worked on the Exo today. Got the bent pin removed and replaced both with the pre-recalled pin setup. I swear it was like a wrecked car, "here is the estimate...there maybe more damage when we take it apart." UGH! Found that the other control arm pin was slightly bent and the driver side differential tab mount was broken. I was able to get it glued back on for now. The driver side shock was wasted as well.
:shock::shock:
Damn lead foot..
:ror:
