Stubs Super Bully!!!
BTW, I had a idea for a new super class.
What if you ran the front end with one TX and RX and then the rear end with another TX and RX? Then you could run as teams with 2 people driving! All it would really take is another receiver. I think it would be fun!
That would be FKN hysterical!! :ror:
Nice start on your diet "thumbsup", what is the O.D. of your tires?
Thanks. A little under 7 1/4".
You're a twin sticker...just feed the rear a little less throttle than the front. ;-)
As soon as I give anything to the rear I loose all drag break. It just free wheels.
WOW that a lot of weight cutting Good work Stubs "thumbsup"
Thank you sir.
Think you could just run the BRXL in the rear only?
I was thinking of that too...it's worth a try since ya already have one of each. If the nuetrals match up then game on!
I'm not sure if that would work or not? I might have another br-sl coming my way? Will someone at BotW have the stuff to program it?
It happening. Eric's rig since its his idea! I'll take the rear sir. Haha
The rear?! Are you sure you want that much responsibility? We may have to trade back and forth. I think the front would be boring and I think the rear would be too much thinking.
I can, just need to remind me to pack the cable.
Okay. We can switch back and forth.
Progress for tonight. C's, link mounts, servo mounts attatched and knuckles clearanced. It came out really nice!
Front
Rear
Yeah, looks proper.
Can you use a smaller rod end on the shaft side, do a rod end cap mod and eliminate the fuel tubing?
I like the mounting to the axles vs the links.
Have you run that servo horn on the back before? Sometimes I wonder if its easier to be more simple and I wonder if the clamping type servo horns actually cause more damage then good since they can loosen??
Does your CVD pin line up with the kingpin since you could push those C's on just a bit further?
I would also throw a set screw/button head on the top and bottom of the C's. It will really firm things up and eliminate any slop in the future. If you allow any slop in the delrin its usually game over after some driving. Gotta keep em right and keep em tight!
OH than you can just each have one front wheel and one back wheel :ror: One take the right side the other takes the left :D
Yeah, looks proper.
Can you use a smaller rod end on the shaft side, do a rod end cap mod and eliminate the fuel tubing? In due time. For now I just want to get it running and the fuel tube works. After BotW I will for sure.
I like the mounting to the axles vs the links. Me too. It is one thing I told DT when he was drawing up the chassis. I just thing it's a better route.
Have you run that servo horn on the back before? Sometimes I wonder if its easier to be more simple and I wonder if the clamping type servo horns actually cause more damage then good since they can loosen?? It has been on there the entire time I've had the super. Zero problems. I ran a longer one on my XR the whole time I had it without failure also. I want to get a long one again for the rear of this. I think I have to much steering for this one to handle.
Does your CVD pin line up with the kingpin since you could push those C's on just a bit further? Yep!
That's a lot to answer!
Well, I got it together for the most part. I still need to fill the shocks and add limiters to them, make panels and hopefully get new ESC's in it before next Thursday.
Rtr minus steering links and body panels.
It's a fair amount of steering.
Ahh...good deal. Yeah, I just learned that you can buy them like that...I didnt know they were called something different though. And yeah, I'll have my setup with me. "thumbsup"
