Redlinerob
Just picked one up.
Any tips on the build ?
Just picked one up.
just drill a new hole towards the outside of the car. I have gone thru 3 of them its the weak spot of the mount and will not take the torque as the motor plate is real thin where they drilled the hole from the factory. It limits how much torque that you can put there and still keep the high power motor meshed up. Since I did that mod no more motor movement. And before anyone says it yes I used loctite and it would still move after a few packsBe careful with the motor mount. I just had to order a new one (GCM) but mine didn't break the way they usually do. Mine developed a hole in the part that mounts to the motor so the set screw wouldn't hold it snug. Not sure I managed to pull that off, but I did.
With the GCM motor mount I should never have a problem again. It's freakin' beefy.
Were can i get one of those? PLMK
I made one of my hinge bolts form a L but it did impact Roy's house at half throttle and four feet off the ground and yes all my carnage has been self inflicted for sureI ordered mine from them at www.gcmracing.ca
The Vanquish motor mount is a thing of beauty also. The only other thing I've broken was a front knuckle, but that was totally due to me taking a bad landing over a huge jump. I've bent the hinge bolts a little but they still work fine. I was bashing on a hill that was 7' or so high and hitting WFO on 3S. So most of my carnage is self induced :mrgreen: They are a hoot to drive though.
good luck with that,rob.maybe my backyard will be done b4 u r.go fast!!"thumbsup"
