mjderstine
SuperShafty.com
So here is a little write up on how i add weight to my wheels. i stick with motoworx racing wheels because they are pretty beefy to start, and can handle lots of abuse. they also look great. cost is good, and they mount all tires really easy.
got some weight in the front wheels tonight. just took some lead, i like to use 2oz sinkers from Dicks, and melted it into the back of the wheels. think its just about 2.5-3oz each. that gets it to the back face of the wheels.
you need to make a plate that goes flush inside the wheel or the lead will just pour through the holes. i used some aluminum flashing.
the trick to get the lead melted. place the wheel in a cast iron pan on med heat to warm the wheel up. other wise it acts like a heat sink and melting the stuff sucks. it just take too long. i like to melt down the 2 oz weights and cut them into small pieces and fill the wheel. give the wheel about 5 minutes to get up to cast iron heat.
then just use a small propane torch to slowly melt the lead. dont use MAPP. or you will burn your wheels. light heat and a little time is all it takes. the wheel gets hot enough to form a perfect lead weight.
you will need to tape the weight out slowly to get the backing out, and then point the lead back in place lightly. the beadlock holds the lead in place. you may need to trim the lead a bit to make it work if you use too much lead.
1.9 wheels
2.2 wheels
1.9 wheels
2.2 wheels
