UPDATE!!!
So I finally decided to stop being lazy and finsh the last major parts of this rig. First was to setup the telemetry for speed and motor temp, wire up the winch/add winch line, and lastly I have almost been dreading the lights wiring the whole entire time. I wanted top off all of the light by added some chassis lights which include rock lights and bumper lights. Anyways here's the finshed product after spending over 15hours the last couple of days having sore finger tips stripping wires, shrink tubing, and solder everything in.
On to the pictures!!!
Telemetry Installed RPM sensor was installed with a braket I made out of lexan to read spur gear rotation via white dot on the spur gear holder, calibration was made through the controller. Temp sensor was mounted on the motor and just installed with the all high tech zip tie. Truck tops out at 13mph!!! Pretty quick for a scaler.
Next! Winch was worked on, harness was installed onto winch and connectors were installed so it could be paired with the Tekin B1R. I spooled up almsot 20ft of the best line I have ever use.
Battery tray was installed. I cut the original Axial metal battery tray a couple inches shorter, drilled and coutersink a couple of holes to mount it all on top of the Axial RX box after the steering servo, velcro was added for better hold on the battery. My power comes from a Thunder Power G6 3s 11.1v 2250mah 65C battery, which fits perfectly in the area it is given.
Rear end lights there are a total of 14 LED lights in the rear of this truck, I love how the rear rock lights came out really showing off the VP Currie axle.
Chassis wiring is finally done. I could almost swear I have hundreds of feet of wiring and shrink tubing in the rig. I tried my best to keep it all clean, functional, and intuitive. For how much I had to hide it think it came out good (please be nice with the comments
Jeep JK body finshed up with the lights harness, 2 light bars and 14 LEDS total.
Wondering how I tie the body to the chassis for lights??? with one 4 pin micro dean and one 2 pin micro dean connectors. Why so many????? You may ask, because the body needs 3 different inputs of power/voltage. It is all quick disconnect and I tired to keep this part clean as possible which for me was very difficult to figure out.
Final pics of this post!!! Since I used a Tekin B1R speed controller as my light controller I was able to turn off and on certain lights at certain points.
Between the 2 VP lights bars and my custom headlights and lights the output of Lumens is just crazy. By far brightest lights ever put on an RC Car
Here's a comparison against my Axial VP Honcho pointing down a dark hallway. Notice the Jeep is better at lights going the distance where's the Honcho is better at a closer range.
Jeep JK
Honcho
After well over 6 months on this build I am going to get to play with it, stay tuned for action pics and videos. I can't say I'm done with the rig because nothing is ever done but I am pleased with where it has come. PLEASE PLEASE PLEASE comment and tell me what you guys think!!! Thank You
