The Crawl Space
Now available from The Crawl Space, The Terra Bridge System, or TBS
-Made from 6061 .063" aluminum stock they are strong, light weight and very durable.
-Rated up to 15 lbs. per bridge with minimal horizontal deflection.
-Terra bridges come in raw finish and can be painted to match most color schemes.
-Side biting "teeth" not only grip in all types of terrain but also allow the Terra Bridge to lock together lengthwise to make wider bridges for heavy trucks, bigger tires or span wide, tire swallowing holes.
Can be easily cut down to fit any rig and mounted in any fashion
Two sizes are currently available.
Terra Bridge V1 measure 1" x 6" designed for class 1 & 2 trucks or trucks running 1.55 - 1.9 tires.
Terra Bridge V2 measure 1-1/2" x 6" designed for class 2 & 3 trucks or wider 1.9 and 2.2 tires.
We can custom cut the TBS to any specific length up to 6" at not additional charge.
Also available for your one stop shopping. The Traxxas "battery hold down plate" set. The metal posts are drilled for body clips and are an easy way to secure your Terra Bridges to your rig.
You will have to drill out 2 of the "centerline" holes on the Terra Bridge for the posts to pass through.
Include the hold down set with your order for just $3 "thumbsup"
$13 per pair shipped USPS CONUS+HI and AK. All others please PM for shipping quote.
Paypal only, no gifts. Send payments to: thecrawlspaceco@yahoo.com
Please include your screen name, the type of Terra Bridge you would like and mailing address in the paypal message.
